It is currently Fri Nov 13, 2026 3:59 am
Post Posted: Tue Aug 23, 2011 4:42 am
what is correct caster for a wt sierra? does any one know?
setting up a wt diff under my coiler soon and would like it to be spot on.
Post Posted: Tue Aug 23, 2011 4:49 am
http://www.zukioffroad.com/Tech_Library ... ations.htm
Post Posted: Tue Aug 23, 2011 7:29 am
Are you running power steer Jonno?
If so, then wind in more caster. IMHO sierras have inadequate caster, and it's mostly because they had manual steering.
Increasing caster makes manual steering much heavier as you are effectively lifting up the front of the car as you steer. However, it's not an issue with power steer so it's a good opportunity to improve turn in and handing.
My WT front diff has (apparently) 3? more caster than a stock WT and I can attest it's massively better on turn in than a stock sierra.
Post Posted: Tue Aug 23, 2011 7:31 am
Auszookers gremlin
Post Posted: Tue Aug 23, 2011 7:47 am
thanks steve i was hopeful you would pop up... currently i have 2' of negative caster due to lift and no caster correction.. yeah it drives shit!
so you would suggest around 6'?
edit
Post Posted: Tue Aug 23, 2011 7:56 am
You sure you have 2deg 'negative' caster? That thing must be nice and wandery over the road
Lil Foot!
Post Posted: Tue Aug 23, 2011 8:03 am
yep.. its pretty average to drive..
Post Posted: Tue Aug 23, 2011 8:08 am
I don't think I'd go +6 - maybe +3?
PS my gwagen runs +8 stock from memory 8O which is why with 65mm of suspension lift and soft shocks it still turns in better than an 80 series with stock caster.
Users browsing this forum: Google [Bot] and 77 guests
