[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
honks
Joined: Tue Apr 20, 2010 11:30 pm Posts: 214 Location: ipswich
 Posted: Sun Sep 04, 2011 11:10 am |
had a broken l/hand engine mount in my 95 sierra about a month ago so i replaced both sides with vl ones trying to put something stronger in but now i seem to notice a fair bit of vibration ar idle and at around 2600-3000 rpm is this a common thing, only reason im asking is that my motor is starting to enjoy a good drink of oil and i'm not sure if it's just some thing in the motor out of balance.Also does any one know anywhere in the brisbane/ipswich area that does exchange motors g13ba as i need my car pretty much all the time and can't afford the down time to get it rebuilt would prefer a straight swap over
Fatzook
 Posted: Sun Sep 04, 2011 11:41 am |
I had no dramas with twin VL mounts on my G16B.
One thing to look at may be the alignment of the gearbox and transfer. The VL mounts are taller, thus lifting the front of the motor. This will ever so slightly change the angle of the rear of the gearbox. I've no idea if its enough to upset the uni's ( doubt it) but it may be worth looking into.
honks
 Posted: Sun Sep 04, 2011 6:28 pm |
i was thinking the same but the vibrations are still there in neutral and bringing the revs up
sogone
Joined: Mon Oct 25, 2010 11:29 am Posts: 2070 Location: Darwin
 Posted: Sun Sep 04, 2011 10:52 pm |
Silly question, but did ya do ya engine mounts properly/tight enough?
ashzook94
Joined: Fri Jan 07, 2011 9:34 am Posts: 67 Location: rocky Qld
 Posted: Sun Sep 04, 2011 11:48 pm |
it might be because the vl engine mounts are made to carry an rb30 not a g13a and at that rev range is where the motor shakes the most so it's goin through the car....
honks
 Posted: Mon Sep 05, 2011 4:37 am |
Sogone: yeh they are tight
ashzook: thats what i was thinking but i was curious if any one else has had any trouble with vibrations when using these mounts as a fair few people on here use them and i have seen them recomended a fair bit
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 108 guests
