It is currently Tue Oct 20, 2026 5:17 am
Post Posted: Wed Dec 03, 2008 1:57 am
i have put new brakes on the rear of my zook!
new cylinders and pads, but i can't get the drum bac on! the pads sit to wide
is there some type of adjustment thingy somewhere or have i done it wrong?
Post Posted: Wed Dec 03, 2008 2:00 am
disconnect the handbrake cable
the adjuster is the cam looking thing with the serrated edge on it, you need to get a screwdriver in where the 2 bits meet to push it in.
put the drums on, give the pedals a few pumps and spin the drums a bit and repeat the pedal pumping until the pedal is good, then hook the handbrake back up and adjust it
Post Posted: Wed Dec 03, 2008 2:13 am
i pushed in the middle and it went in but the pads didn't move!
Post Posted: Wed Dec 03, 2008 2:14 am
wiggle em a bit, sometimes they suck to line up and get in
Post Posted: Wed Dec 03, 2008 2:27 am
Push the cylinder together too, that might get you some more movement
Post Posted: Wed Dec 03, 2008 3:12 am
Aren't you supposed to have your shoes ground to match your drums or something like that? Not that I did when I last changed shoes.
Post Posted: Wed Dec 03, 2008 3:15 am
You need to be careful, there are two different size drums. You need the right shoes for the drums
Post Posted: Wed Dec 03, 2008 12:09 pm
Damo, yes yuou should if you are talking oversize drums through machining
ScrawnC, its a coily so I think there is only one set, but not to say he hasnt got 1 litre front shoes or something :)
Post Posted: Wed Dec 03, 2008 3:25 pm
That's what I was thinking, maybe they gave him the wrong shoes?
Post Posted: Wed Dec 03, 2008 10:05 pm
Did you check your drums to see if they needed machining?
lesspostingmorewheeling
Post Posted: Wed Dec 03, 2008 10:53 pm
make sure you didn't put 2 of the same shoes on the same side
Post Posted: Thu Dec 04, 2008 12:08 am
i have had the drums machined!
and its for my ute royce not he coily! do they have different shoes?
Post Posted: Thu Dec 04, 2008 12:15 am
yes there are about 700 different types
how far off fitting are they?
Post Posted: Thu Dec 04, 2008 12:21 am
not much prob around 2mm
Post Posted: Thu Dec 04, 2008 12:29 am
adjust and wiggle
Post Posted: Thu Dec 04, 2008 12:58 am
bfh then swear when you realise they gave you the wrong pads.. :)
i was given two sets by a mate that worked at a brake place .. when compared next to each other one of the sets holes were slightly diff and the pad overall was longer if that makes sense. :S
Post Posted: Sun Dec 07, 2008 3:51 am
yea i just had a measure of my cylinders and they are 5mm longer than my old ones
Vehicle: 75 Cruiser
Post Posted: Sun Dec 07, 2008 2:29 pm
same has happended to me a few times. Usually just squeeze everything together and just fits on. One time i swapped the drums to the other side of the car and it fitted. or grab a slightly more worn drum that you have laying around and it'll fit.
I think you can also get different brake cylinders which may push the brake shoes out further, making it impossible to get the drum on.
Just check all the bits you bought with your old bits to see if they're all the same.
Users browsing this forum: Google [Bot] and 271 guests
