It is currently Fri Nov 13, 2026 12:53 am
Post Posted: Thu Oct 27, 2011 1:24 am
Hey guys. I just recently bought a Baleno to do a conversion into my sierra.
first of all tho i'm going to teach my sister how to drive.
As it turns out the water pump needs replacing. So i've got a new pump and
went to put it in and its about 30 - 40mm off the side wall and i just cant get to about 3 of the bolts holding it on. There is air con and power steering pipe passing around this area as well making at an absolute prick and reminding me why i love my sierra so much lol.
I was wondering if it would be easier to undo some engine mounts and jack the motor up a little to get to it all. Or if any of you guys know an easier way could you please share
Post Posted: Thu Oct 27, 2011 1:44 am
Jacking the engine up could give you enough room.
You are fitting a new timing belt as well aren't you?
Post Posted: Thu Oct 27, 2011 4:52 am
nope. it just had the timing belt done 2 weeks ago and they didn't do it then so i guess it gave up due to karma =S lol .
i only just bought it 2 days ago and thats all it needs. just had a new clutch & bearings done and gearbox bearings done too. bit of a bargin really.
Post Posted: Thu Oct 27, 2011 10:16 am
Have you removed the access panel that allows you to get in around the lower crankshaft pulley? I don't remember too much about that, I'll try and have a look at it when I get home.
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Post Posted: Sat Oct 29, 2011 12:30 am
is the access pannel the cam belt cover because i'm just about to pull off the crank pully to get the cover off. lol
Vehicle: 1995 Suzuki Vitara JX LWB G16B
Post Posted: Sun Oct 30, 2011 5:09 am
take the wheel off that's on the side of the car your working on and remove the plastic or acces cover behind it i assume,
fwd = access nightmare
89 Sierra (Crashed)
95 Vitara (Current)
Users browsing this forum: No registered users and 55 guests
