It is currently Thu Nov 12, 2026 8:57 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2
Post Posted: Mon Apr 19, 2010 5:49 pm
works fine on a WT, I had one
Post Posted: Mon May 10, 2010 9:30 pm
i think i am having a win with this. :lol:
the bracket thing on the pitman is cracked and there is a shitload of movement
between the dampener and the pitman so i will bodge up a new mount and
hopefully it will fix the shakes.
Post Posted: Tue May 25, 2010 8:02 am
i took the steering dampener off and that fixed my wheel wobble :D
the dampener had cracked mounts that were flexing as well as flogged out bushes. :lol:
Vehicle: 93 Sierra
Post Posted: Tue May 25, 2010 8:07 am
Groovy! Anything else you could see under there that looked removable? Keep going till it all goes pear shaped! :P :D
Post Posted: Tue May 25, 2010 8:43 am
thats how i normally deal with stuff, have you seen my carby threads? :lol:
Vehicle: 93 Sierra
Post Posted: Tue May 25, 2010 8:54 am
Haha yep ... just cos you get away without needing a choke or getting EPA tested up there :P
Post Posted: Fri Nov 25, 2011 2:18 am
i am having another look at this as the wheel wobble is getting quite bad.
the wheel shake is just the passenger side, different tyres and rims have been tried.
just stripped the hub and while the wheel bearings aren't awesome they look pretty good considering i fitted them
before i joined AZ
the king pin bearings are like new. the only thing that looks worn is the drag link tie rod.
it isnt real bad but has about 2mm of slack, probably caused by the wheel wobble.
any ideas?
Post Posted: Fri Nov 25, 2011 6:11 am
scraper seals would have to be flogged by now, they are a 5000km severe service item and dampen the hubs more than the king pin bearing tension ever could
Post Posted: Fri Nov 25, 2011 8:26 am
Prove it, cause if you can you just sorted part of the alleged Jim wobble... :helloo:
Post Posted: Fri Nov 25, 2011 8:38 am
get a spring scale, setup king pins per normal
fit scraper seals, check tension again, its heaps higher
ive been telling you lot for years to replace the fucking scraper seals, but nobody listens to the guy with the simple answer
Post Posted: Fri Nov 25, 2011 8:54 am
i have a set in the shed so i will give it a go tomorrow.
today i replaced the wheel bearings and repacked the cv and king pin bearings
plus went back to stock shackles however due to the beer i drank while doing it i cant test drive it.
Users browsing this forum: pete_79 and 77 guests
