It is currently Thu Nov 12, 2026 5:34 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2
Post Posted: Sun Jan 08, 2012 8:55 pm
jdk81 wrote:
ZookFan wrote:
Damo wrote:
Yes rebuilding the carby will do a lot if the engine is rooted :lol: :roll:
First thing I would be doing is a compression test.
Really what like?? :?
I see your sarcasm detector is working well :roll:
Don't think there was any to detect.......
if the eng has burnt valve's you car rebuild the carb till daisy stop's milking but it won't fix the problem, carby is not always the culprit....
:helloo:
Post Posted: Sun Jan 08, 2012 8:58 pm
Bombero wrote:
Check the butterfly in the carb fully opens with your foot flat to the floor. Sometimes is a prob
That is a very good point.
Sometimes the wheel arch mods we do for bigger tyres can limit the accelerator pedal.
I had to space mine, on the floor, to get full carby operation.
Plus the secondary throat can fail on carbs.
Post Posted: Mon Jan 09, 2012 3:44 am
who buys a zook to go fast
if you want to go fast in a sierra keep it stock and then put a 250hp 20valve turbo 4age in it like me :twisted:
rust is lighter then carbon fiber
Post Posted: Mon Jan 09, 2012 4:46 am
I've read 5 post's of yours today & all trying to talk your self up, we all Know about your shitty toyota eng's...... :helloo:
Post Posted: Mon Jan 09, 2012 4:56 am
its not my fault ive finsihed work dropped my heap of shit of a suzuki at the shop to get fixed and i got nothing to do :helloo:
Post Posted: Mon Jan 09, 2012 5:16 am
Every post mate, has a mention of you eng...... :crazy:
WE KNOW!!!!!!! :helloo:
Post Posted: Mon Jan 09, 2012 5:18 am
WE KNOW!!!!!!! we don't care :D :helloo:
FIXED :P
Vehicle: 1996 Coily, G16B.
Post Posted: Mon Jan 09, 2012 5:41 am
When my girl was a 1.3 Carby I had the same issue of no 5th gear option and maximum of like 110.. so you're not alone...
now that i've converted her to 1.6 EFI 5th gear is my best friend, not sure how fast she goes, but she's definately going faster that 110 and not struggling to do so.
...maybe time for upgrade :D totally worth it :)
^.^ Mad toys aren't just for boys! ^.^
Post Posted: Mon Jan 09, 2012 5:45 am
You should start a build thread on your car even though it's only a coily :thefinger: :helloo:
Post Posted: Mon Jan 09, 2012 5:46 am
haha i haven't done much to her to start a thread :P ahah coily <3
Post Posted: Mon Jan 09, 2012 5:56 am
Haha yer I have worked on it all day today and she is still a slug ran a straight tho exhaust for a bit it's sounded tuff but still no quicker carby seems fine also. And I didn't take to the gaurds extreme enough to effect throttle travel. Just out of curiosity what's a 1.6 conversion goin to cost me I know Its lazy and I could most likely find it on here somewere but just a rough estimate would be sweet. Once again cheers everyone for your inputs.
Post Posted: Mon Jan 09, 2012 5:58 am
G16B 1600cc 16 valve fully reconditioned motor.
H/Duty Dakin excedy clutch kit
Radiator
Extractors & full 2" exhaust system.
Coolant hoses, thermostat, coolant, oil, gaskets to do install.
Adapter kit for 1600 motor.
Custom air intake hose.
Injection manifold, wiring & ECU.
EFI external fuel pump & filter setup.
Service injectors.
Labour for wiring & installation.
cost me $8,165.39
Post Posted: Mon Jan 09, 2012 5:59 am
All brand new parts 12 months warranty, I also got a second hand battery which only has 3 months warranty due to well ... being second hand
Post Posted: Mon Jan 09, 2012 9:13 am
Thanks for that buddy wasn't expecting that detailed at all. Sounds like it's worth doin, gona have to sweet talk my ass off to the missus to pull it off tho lol.
Post Posted: Mon Jan 09, 2012 9:36 am
Fck me. 8k??? Buy a Suzuki that already has the conversion for a lot less!
Post Posted: Mon Jan 09, 2012 9:37 am
huuuuge difference. lol. ahaha sweet talk :P good luck with that.
Post Posted: Mon Jan 09, 2012 1:18 pm
I towed a 400kgboat and trailer (approx) the last few days with my 1.3 carb and still sat comfortably on 105kph in forth on 235 75's. Did not even look like overheating or struggling and held 100kph going up a slight incline without drama. (for me 4th gear is about 3900rpm at 100kph). My engine is completely stock with 250 000 on the clock and nothing but a few timing adjustments and good fuel.
I would sugest there is something wrong but decide what you want before spending anymoney. no point replacing everything if your not gonna be happy and do a engine swap anyway.
oil lights are like oven alarms, let u know its co
Vehicle: 93 Sierra
Post Posted: Tue Jan 10, 2012 5:29 am
I know these comparisons are kinda useless, but for what it's worth I did similar. Crossed the Nullabor with a 400kg trailer behind my loaded Zook (me + wife + 2 dogs + travel gear) with a 1.3L and 235/75R15's and was able to sit on 100-110kph in 5th except where I was into headwinds, when it knocked me back to 90kph in 4th (or 80kph in 5th and starting to lug a bit).
Not knocking your decision to put in a 1.6L SUPAZOOk but 8k is a lot of coin to drop on a Sierra for most people. I spent somewhere approaching 2k rebuilding my 1.3L from the sump up with new everything (carby service and tune, clutch, fuel pump/lines, radiator, etc) and am very happy with both its performance over the last 30,000km and its reliability. You could rebuild a 1.3L for a lot cheaper than that and still have a pretty high degree of confidence in the rebuild.
Post Posted: Tue Jan 10, 2012 5:31 am
:) s'all good
Post Posted: Tue Jan 10, 2012 5:32 am
8K That's fucking insane prices, where'd you go Suzistore?
I'd want a turbo 1.6 for that price.
helloo
Post Posted: Tue Jan 10, 2012 6:03 am
yeah i went to suzistore. i got it towed from rocko to midland too.
ah well - i'm happy with it :P
Post Posted: Tue Jan 10, 2012 7:04 am
Just had a new plan should invest in a car trailer and just tow the thing behind the Hilux that way I would get easily 110 and I would have airconditioning to!
I have no problems rebuilding the engine from the ground up but it would be a fair kick in the teeth if it was just as slow once it was all done.
The mate that bought my old zook still don't have his license back so I might chuck my tyres and transfer case in his and c what happens.
Users browsing this forum: No registered users and 57 guests
