It is currently Wed Nov 11, 2026 5:16 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2
Post Posted: Thu Feb 16, 2012 9:36 am
Sweet yh i got my old one i munched a pinion on so that will work just fine.
I love lamp
Vehicle: nt sierra
Post Posted: Thu Feb 16, 2012 4:29 pm
what product do you guys use for sealing up the welds?
Im no boiler maker so im counting on some product to make my welds oil tight.
ive used the metal putty in my shave and im fairly sure my car should be nick named 'The Sieve'
Perhaps a silicone based product would have achieved better results but i thought this might be a bit prone to failure in a diff housing.
Post Posted: Thu Feb 16, 2012 4:46 pm
learn to weld better or get someone that can weld properly to do the job for you.
Vehicle: nt sierra
Post Posted: Thu Feb 16, 2012 4:53 pm
:roll:
learn to post some positive information or get someone to do it for you
i believe i asked about sealing products not about my welding skills.
Post Posted: Thu Feb 16, 2012 5:15 pm
seal it with a decent fucking weld was my point you simpleton.
it appears it's not just your sierra thats slow..... :roll:
Post Posted: Thu Feb 16, 2012 5:25 pm
fight fight fight fight fight!
sikaflex would do it (i can't remember the number off the top of my head). Still, i wouldnt trust the sikaflex to hold pressure, which a diff goes through when its nice and hot and you go flying through a nice deep puddle of water...
Vehicle: nt sierra
Post Posted: Thu Feb 16, 2012 5:39 pm
Cheers Alien.
:roll: i remember the first time i acted tough on an internet forum...
Post Posted: Thu Feb 16, 2012 5:41 pm
lol your keen taking advice from a graphic designer.
:thefinger: @ alien :lol:
Post Posted: Thu Feb 16, 2012 5:46 pm
I dont think it was meant as an insult. Its better to do something right in the first place rather than fuck it and bodgy it fixed. If ur really worried take ur diff apart and grind out ur welds and redo it. this is a bajillion times better than putting putty in it which will most likely come out and munch ur diff and seals to bits
I love lamp
Post Posted: Thu Feb 16, 2012 5:50 pm
:goodjob:
Post Posted: Thu Feb 16, 2012 5:55 pm
you know, i almost wrote that he should buy it in black, cos it looks nicer even if you're coating it in paint? =)
Post Posted: Thu Feb 16, 2012 6:07 pm
Diff shaves are a NIGHTMARE to seal up - it's not uncommon to have a couple of little weeps from them.... but I just mean oily stains on the housing, not actual dripping leaks.
I would agree with buffing the welds back with a flap disc and having a very good look for any imperfections - even tiny ones will weep oil once the paint gets rubbed off. If you wee anything, reweld and buff back again. Repeat 6867586757 times.
I would not use a sealant. IMHO it's never going to last in that environment.
Post Posted: Thu Feb 16, 2012 10:28 pm
After a diff shave I pop a bung in where the outer seals go, then fit a blanking plate over the third bolting flange, and shove 60psi up its arse ( through a hose on the breather ). Then you spray the welds with soapy water and look for bubbles.
No bubbles, means no oil leaks 8)
Post Posted: Fri Feb 17, 2012 5:25 am
X2
but 10 psi is heaps
Post Posted: Fri Feb 17, 2012 5:26 am
Another option would be to buy some penetrant test aerosol cans from an engineering supplier.
Spray the penetrant on the inside, leave it 1/2 an hour or so, and check to see where it's worked its way through by spraying developer on the outside.
This stuff is available from most bearing sales/engineering supply places.
http://www.rocol.com/corp/index.php?opt ... Itemid=428
Should only be $20 a can or so and only two cans are really needed (penetrant/developer) cleaning can be done with carby/brake cleaner or thinners.
Post Posted: Fri Feb 17, 2012 7:38 am
x2.
That's how we crack tested the crossmember recall on the Hiluxes when I worked at Toyota. Awesome stuff.
Post Posted: Fri Feb 17, 2012 8:48 am
Used that stuff to check welds at my old work, after doing mechanical testing on the piece welded. great stuff.
Vehicle: nt sierra
Post Posted: Fri Feb 17, 2012 3:01 pm
dwelling on it for a bit (mrw82 will love this) im going to have to rip the metal putty out and hit the welds up again. its far too a contaminated/volatile area.
But once i get it to a point where its just weeps out i think ill give brazing rods a go. But there is no welding back over it once i do that.
For leaks i just put the 2 bottom bolts in and fill with water and wait a bit. other wise its a pain/ cost to clean the area again, so i can weld over.
Post Posted: Fri Feb 17, 2012 4:15 pm
Anyone remember Twisty's FJ40 Ubolt mounts? I always liked them, might need a little rethinking with the thin zook spring packs but the concept is good.
Post Posted: Fri Feb 17, 2012 5:40 pm
Yh they look pretty good too could be another option. Im goin away for a week before i start it so ive got some thinkin time haha
I love lamp
Post Posted: Fri Feb 17, 2012 7:07 pm
Did the same when my mate made my fuel cell, except we put a bit too much pressure in and ballooned it :oops:
Made in JP. Built in WA.
Post Posted: Sat Feb 18, 2012 8:47 am
Haha more capacity woohoo haha
I love lamp
Users browsing this forum: No registered users and 49 guests
