It is currently Thu Nov 12, 2026 7:05 pm
Post Posted: Thu Mar 08, 2012 8:05 pm
The GV has developed a squealing sound (like a belt slipping) with the a/c on, sometimes it makes the noise sometimes it doesn't
I've had a quick look and can't see where the p/s or a/c can be adjusted, is the a/c & p/s belt adjustable on the 2.5 SQGV or do they have a belt tensioner thingo?
Post Posted: Thu Mar 08, 2012 8:42 pm
AC belt adjustment is on the idler pulley. There are two bolts through the centre, one is in a round hole, the other slotted. There is also a hexagonal hole that takes an large Allen key.
Loosen off the bolt in the slot. Loosen the other bolt just a little.
Adjust the position of the idler with the Allen key.
Retighten bolts.
There isn't much room to get your hands down behind the radiator, but it can be done.
It takes plenty of tension on belt to stop the slip, it doesn't have much wrap around the AC pulley.
Post Posted: Thu Mar 08, 2012 8:55 pm
Cheers mate ill have a go at that tomorrow arvo, i tried getting my hand in there but couldn't so ill take the fan off first
Vehicle: Sold zuk got a Bt50
Post Posted: Thu Mar 08, 2012 9:38 pm
Prepare for blood knuckles
bt50 now but still love the zooks
Post Posted: Thu Mar 08, 2012 10:08 pm
Vehicle: 2004 SQ625 GV
Post Posted: Thu Mar 08, 2012 11:51 pm
Both my cars are idler pulley for PS belt tension and adjust the AC compressor for AC belt tension. maybe a two beer job.
Post Posted: Fri Mar 09, 2012 6:13 am
But aren't they the same belt?
Post Posted: Fri Mar 09, 2012 7:08 am
If its a pain in the ass to do, chuck a new belt on it, if its stretched enough to squeal itll be rooted soon anyway
Post Posted: Fri Mar 09, 2012 8:59 am
:oops: you're right its the alt that has the separate belt. so yeah it's just the idler puller.
Post Posted: Fri Mar 09, 2012 10:55 pm
Put a new belt on and all good till five mins later and a little bit of a squeal came back when under load with a/c on :x nowhere near as bad as what it was though
Ill have another go at it in the morning with a longer allen key for more leverage :)
Post Posted: Sat Mar 10, 2012 11:33 am
Fyi, some belts tell you to install the belt and tension. Run for 5 minutes and retension.
Post Posted: Mon Mar 12, 2012 10:45 pm
I told you to give it plenty of tension....
Post Posted: Tue Apr 10, 2012 1:06 pm
What size allen key did you use ??
Post Posted: Tue Apr 10, 2012 1:36 pm
Can't remember off the top of my head I'll have a look when I get home
Post Posted: Tue Apr 10, 2012 2:01 pm
thanks as nearly all my tools are in darwin i need to buy one. But just want to buy the 1 not a whole set
Post Posted: Wed Apr 11, 2012 9:11 am
9mm mate
Users browsing this forum: Google [Bot] and 54 guests
