It is currently Fri Nov 13, 2026 1:42 am
Vehicle: 1985 Sierra Hardtop
Post Posted: Wed Apr 11, 2012 8:35 pm
hello,
is there a trick to getting the front rotors off a Sierra?? i had a quick go at removing them but couldnt see how to get them off?? i didnt go too far with them though as i ran out of light. do i need to remove the locking hub parts or will the rotors slide off past it?
cheers
Chris
Post Posted: Wed Apr 11, 2012 8:40 pm
You'll see two holes in the centre part of the rotor.
They fit an M8 bolt. Wind in some bolts it should pop off. If not, wind them in tight then try and knock the rotors off.
Post Posted: Wed Apr 11, 2012 8:44 pm
ah k i did see the bolt holes, i thought bolts were missing!! ha ha! i'm used to old cars like my Escorts that have a bolt or two to hold the drum on!! i will give that a go
cheers
Post Posted: Wed Apr 11, 2012 11:05 pm
If you are replacing the rotors the easiest way to remove them is to:
Jack up front and place axle stands.
Remove wheel.
Remove caliper.
Belt the rotor with a hammer until it falls off. Hit it anywhere except the wheel studs, hurting the rotor doesn't matter as it is going in the bin.
Users browsing this forum: No registered users and 59 guests
