It is currently Wed Nov 11, 2026 5:23 pm
Post Posted: Wed Apr 25, 2012 1:28 am
OK so im looking at a leafy tomorrow and I wanna do a bit of reasearch before i do.
Whats the differences between a WT and a NT ie. Appearence, aftermarket parts and performance.
After owning a coily i wanna make sure i get one to suit what i wanna do, not to say im bagging coilys, just doesnt suit my needs.
Thanks, Brent
SJ80 Coily 2 inch body+40mm lift+31 inch M/T=:D
Post Posted: Wed Apr 25, 2012 1:38 am
WT's have the wider steel flares, updated grille, different dash ( IMO the NT dash looks better) and different gear ratios.
I've said this before, but if you are looking to build a capable offroad vehicle buy a NT sierra and do WT diff swap ( gives better articulation due to inboarded springs )
All aftermarket parts ( upgrades ) fit NT and WT 1.3L sierras.
Post Posted: Wed Apr 25, 2012 1:57 am
Sorry to be a pain, i just wanna pick ur brain a bit, whats so different about the nt to the wt after u change the diffs to make it more capable?
and what years do the nt and wt range through, coz im still a noob when it comes to leafys.
Post Posted: Wed Apr 25, 2012 1:59 am
i could have worded that better...
why is a nt with wt diffs more capable then a wt?
Post Posted: Wed Apr 25, 2012 2:10 am
The inboard spring spacing of the NT coupled with the wider WT diff creates more leverage and hence more flex than a WT or NT stock. Also has the advantage of more room before big tyres foul on the spring at full steering lock.
Post Posted: Wed Apr 25, 2012 2:11 am
ok sweet, thanks guys.
Post Posted: Wed Apr 25, 2012 7:47 pm
NT 1.3 1984ish to 1988 (generally 1987 build would be the latest you'd see.)
WT 1988.5-1996
Post Posted: Thu Apr 26, 2012 10:39 am
Aftermarket HD CVs and Axles are only available off-the-shelf for WT. But otherwise agreed.
Post Posted: Thu Apr 26, 2012 10:50 am
Aftermarket HD CV's are available off-the-shelf for NT. But otherwise agreed. (CrMo cv will go on a stock axle.)
Post Posted: Thu Apr 26, 2012 11:36 am
Wouldnt the stock axle be 22 spline? Whereas the HD CV would be 26 spline?
Post Posted: Thu Apr 26, 2012 11:49 am
actually the cheaper double toughs from lowrange have a 25 spline into the cv
Post Posted: Thu Apr 26, 2012 11:50 am
They are 26 spline where they go into the diff but fairly sure still stock number in CV.
EDIT:
Just checked and they are 26 spline both ends. So CV won't go on a stock axle... :oops: :oops:
Users browsing this forum: No registered users and 67 guests
