It is currently Tue Nov 10, 2026 11:22 am
Post Posted: Wed Jun 13, 2012 12:44 pm
hi guys got a 89 sierra with the standard 1.3. i had a look at the engine earlier and noticed the hose that comes off the charcoal canister and along the firewall itsnt connected to anything and the back of my fuel pump seems to be leaking fuel? is the hose suposeto go to the fuel pump?
Post Posted: Wed Jun 13, 2012 12:46 pm
my fuel pump is missing this bit of pipe
Post Posted: Wed Jun 13, 2012 1:07 pm
thats a telltale pipe , has been covered before , it leaks oil when the pump is on its way out... do not connect anything here.
at the base of the carb on the rocker cover side there should be three pipes , one goes to vac advance on the dizzy , one goes to the vsv on the front of the engine for the egr , and the other goes to the carbon canister.
Vehicle: '94 suzuki maruti
Post Posted: Wed Jun 13, 2012 6:02 pm
x2. if that hose is leaking fuel, replace the fuel pump. it means the diaphragm is busted and your fuel and oil are mixing.
Post Posted: Wed Jun 13, 2012 7:43 pm
already orderd one and it will be here tomorow =) cheers guys. cant seem to find were the charcoal cannister hose goes tho. i found the vac advance and the vsv hoses but there doesnt seem to be anywere for the charcoal canister hose to go to but will have a look tomorow in the light
Post Posted: Thu Jun 14, 2012 9:58 am
Some carbs don't have as many vac points as others, it may be a replaced carby.
Some have vac points in hidden and different places.
Post Posted: Thu Jun 14, 2012 10:07 am
USA pic but may help
Post Posted: Thu Jun 14, 2012 10:10 am
Post Posted: Thu Jun 14, 2012 12:09 pm
Isn't the charcoal canister supposed to have a vent?
I found a hose hanging from the canister on my GV, had me baffled for a few weeks, until I could get a look at another GV - the hose was a vent line that would normally run to a fitting on the outside of the air filter housing - it didn't connect to the air filter, the purpose of the fitting was just to keep the end of the vent line high up.
Users browsing this forum: No registered users and 73 guests
