It is currently Sat Nov 07, 2026 9:52 am
Post Posted: Mon Aug 13, 2012 5:08 am
Any tips on making a fuel tank? What matirial? Thichness? Design tips?
Thinking about a sub tank for the LWB Sierra, and maybe a couple of sill tanks for the Rangie.
I have access to a gulitone and folder at work so may as well make some use of it
Rick
Vehicle: 2003 Jimny Auto
Post Posted: Mon Aug 13, 2012 6:16 am
I'd love a set of sill tanks for my jimny
Post Posted: Mon Aug 13, 2012 6:30 am
Most factory tanks are about 0.8mm thick black steel which is then zinced but they have allsorts of corrugations for extra strength.
Aftermarket tanks are just flat sheet so need to be a bit thicker EG 1.6 - 1.8mm.
Work hard on the design so you can have as many folds and as few welded seams as possible.
I'd be incorporating a swirl pot and baffles if making a tank from scratch, but a sub tank doesn't really need them.
Not sure where you'd get the fittings for sender unit etc.. Maybe chop up an old tank... CAREFULLY.
Post Posted: Mon Aug 13, 2012 12:18 pm
Buy aftermarket. Autometer sell senders with guages to suit.
Post Posted: Mon Aug 13, 2012 12:59 pm
Most of the boat shops like Bias Boating, Whitworth etc. sell neat looking fuel gauges want the senders are designed for varying depth aftermarket application
Vehicle: SJ51T
Post Posted: Mon Aug 13, 2012 5:57 pm
I have this on my to-do list as my factory one is all beat up now.
I was going to combine a bash guard and larger tank into one.
ie, make the bottom plate thicker so it is dent-resistant.
I have a 2" body lift so was going to make the tank higher aswell to extend the capacity.
Be my guest on stealing my ideas so I can copy you :)
Post Posted: Tue Aug 14, 2012 4:06 am
There is a plater in town, not sure if he does zinc but cad plates. Will has to sus this out.
Baffles in the Rangie sill tanks maybe, as they will be long and skinny. Sierra..... don't know.
Subs would feed into the main with lecky fuel pumps, so wasn't going for swirl pots or guages. Make the subs smaller than the main tank.
As for design, was thinking two 'U' shaped halves welded together, is you get what i meen.
Post Posted: Wed Aug 15, 2012 5:26 am
U shaped halves sounds the goods best would be if you could press all four sides from the base this would be ideal but u would need a specific press or folder.. as for material stainless is best don't need any coatings that will eventually deteriorate as for thickness go for 2mm plus would be plenty strong and easier to weld
Post Posted: Wed Aug 15, 2012 6:03 am
I didn't mean the sender or the gauge.... I meant the flange bit the sender screws into.
Post Posted: Wed Aug 15, 2012 6:37 am
stainless can work harden and crack around the welds , particularly the mounting tabs
most aftermarket tanks are made from aluminium coated mild steel
apparently zinc/gal sheet reacts with fuels, but Ive never seen it?????
the feruls/sockets for outlets, plugs etc can usually be had from bearing wholesale etc
Vehicle: '92 Sierra
Post Posted: Wed Aug 15, 2012 12:41 pm
This is what I did. I bought a VS commodore tank off ebay and took the mounting flange, swirl pot, in tank pump, sender etc and fitted to my long ranger. The VT ones look to have a good top mount one where the pump, sender and swirl pot unbolt as one. The top mount idea is a bit of a pain though. The mounting flange came out after drilling just 4 spot welds.
Users browsing this forum: No registered users and 48 guests
