[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
burls
Joined: Sun Mar 07, 2010 10:30 pm Posts: 989 Location: Ipswich
Vehicle: 95 sj70 and 78 lj81
 Posted: Sun Aug 19, 2012 1:16 pm |
Looking to get a new filter for my 1.6 just wondering if anyone has found a cheaper (read that not worse quality) filter to use. Like a high use item out of a commy or something
bulladean_
Vehicle: tin top sj70
 Posted: Sun Aug 19, 2012 1:20 pm |
hey burls did you buy you sierra off a guy in townsville called matt ?
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Sun Aug 19, 2012 1:40 pm |
If you are talking about a G16B EFI filter, yes, you can use a VL commodore filter, they are pretty cheap. However, this is a "point of no return" mod as you'll need to cut the banjo fitting off the HP hose coming from the tank.
I had a VL commodore filter on my car when it was 660cc powered (vitara tank) I've since swapped to a proper G16B filter to retain the banjo fittings.
I bought a replacement G16B filter from Repco and didn't remember it being very expensive?
Shandy
Joined: Tue Apr 26, 2011 3:48 am Posts: 45 Location: canberra
 Posted: Sun Aug 19, 2012 2:11 pm |
Repco do a universal replacement. RFF75 has a crown around it to run the pipe in in any direction. Around $27
Gwagensteve
 Posted: Sun Aug 19, 2012 2:27 pm |
I think that's about what I paid.
You might be able to find a VL filter for $10 or so, but in any case, and EFI filter shouldn't require replacement very often - there's a strainer on the bottom of the pickup that catches most of the junk, so there shouldn't be much debris making it's way into the filter.
burls
 Posted: Sun Aug 19, 2012 3:22 pm |
Thanks guys
Steve I am at the start point, thats why I didnt designate a car. I can fit any filter I like (within reason) as I have to make the brackets and all the lines. This is in my LJ81. So the idea was to find a common use filter that is cheaper due to volume sales not quality.
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 104 guests
