It is currently Fri Nov 06, 2026 10:58 pm
Vehicle: Nl pajero Lwb, 98 jimny
Post Posted: Mon Aug 20, 2012 8:15 am
Hi guys I know it's all been said and done before but wanted to confirm Suzuki liana 1.6 engine is this suitable replacement for 98 jimny g13bb? Many issues or straight swap?
Post Posted: Mon Aug 20, 2012 9:41 am
is the liana a M series or a G series block?
Post Posted: Mon Aug 20, 2012 9:47 am
If its a 98, g13bb, the liana engine wont bolt up and you will nead to source an m series gearbox
Vehicle: On the lookout
Post Posted: Mon Aug 20, 2012 10:31 am
Pain in the butt. You need the M-series Loom, ECU, Clock, Imobilizer, etc...
Stick with a bigger G-series. One of the reasons M-serires conversions are popular is to replace smaller M-series engines with ease. If you are trying to put the large amount of effort/money in to replace a G-series with an M, you may as well put something awesome in like a suzuki Swift GTI m-series or something rather then a wheezy Liana/ignis m-series. my 2-cents.
EDIT:
Just had a VERRRY quick look through the useful tech threads and the like, seems you are barking up the wrong tree, loads of threads on Baleno G series upgrades etc. Have a search. Seems to me M-series Liana M16 is most definately NOT the engine you want to replace a G13
Post Posted: Mon Aug 20, 2012 10:48 am
Personally i would do: (in order of easyness and cheepness)
g16b from a baleno
g16b from a vitara
J20A from a vitara
J18A from a baleno GTX
J24A from a GV or Kazashi
All of these should bolt up to your Gseries gearbox using the benT kit though you may need to do some funky things with flywheels
Post Posted: Mon Aug 20, 2012 10:50 am
g16b from a baleno
g16b from a vitara
J20A from a vitara
You saying a G block and J block are the same bellhousing pattern?
Post Posted: Mon Aug 20, 2012 10:58 am
YES!!! :)
My J20a is bolted direct up to a G16B AW4
Post Posted: Mon Aug 20, 2012 11:08 am
I don't believe you. I'm going to go check it now.
Post Posted: Mon Aug 20, 2012 11:13 am
Believe it or not :)
the 4 speed auto i bought from you from an x90 and my J20 from the sierra
Post Posted: Mon Aug 20, 2012 11:15 am
you do need to play with the flywheel as the J20 has an 8bolt flywheel and is too big to fit in the G16 bell housing and the G16 has 6 bolts.
If you find a J18 flywheel its the same size as the G16 but with 8 bolts.
Post Posted: Mon Aug 20, 2012 11:31 am
tanshi wrote:
YES!!! :)
that would be a smoking combo, i can't believe how nice the auto is in my new LWB.
Post Posted: Mon Aug 20, 2012 11:50 am
Im not 100% sure how the 1.6 torque converter and ECM is going to react with the different engine characteristics but JRzook from here is working on a magic box which should make it go.
Really looking forward to seeing how it goes in the LJ, just need to get my cage sorted in the cab as thats whats holding the build up.
Post Posted: Mon Aug 20, 2012 12:45 pm
Ok cheers guys I just want to upgrade as easily as possible from 1.3 to 1.6 efi same flywheel and clutch/gearbox combo if possible just after a LOW km engine is the key and ease of install. Basically want to unbolt old and bolt new in.
Post Posted: Mon Aug 20, 2012 1:22 pm
Such a beast doesnt exist unless you buy an engine thats already modified for your model of car.
Baleno needs wiring changes, cooling system changes.
vitara needs wiring, and engine mount changes.
and they get harder from there.
Post Posted: Mon Aug 20, 2012 1:47 pm
Hmm could be easier to whack it in the shop and let them deal with it. Been quoted $2k for drive in drive out 1.6efi engineered in jimny... Sounds like the right price? After buying engine...$700? Parts to modify?$300, pain in the ass and taking up my weekend loss of work to do conversion $600 a day, engineering etc $?? Shop sounds like the easy cheap way out!
Post Posted: Mon Aug 20, 2012 1:59 pm
Thats a goodish price if it's excluding parts, and it's a great price if it including parts. IMO.
Post Posted: Mon Aug 20, 2012 2:21 pm
That's Drive it in with 1.3 then Drive it out with 1.6 so I am assuming inclusive of everything.Just drop it off and pick it up is all I have to worry about!
Post Posted: Mon Aug 20, 2012 2:23 pm
yep, for that price as long as there are no hidden extras, ive bought engines for almost that
Post Posted: Mon Aug 20, 2012 4:44 pm
Sweet I thought that by buying low km engine and swapping it out myself would save some coin, but if it's going to be a pain in the ass I will get someone to do it and just enjoy the benefits!
Users browsing this forum: Google [Bot] and 106 guests
