It is currently Sat Nov 07, 2026 10:57 am
Vehicle: 1.3 Tin Top
Post Posted: Wed Mar 13, 2013 3:20 pm
car has been running like a pile of shit every now and then for a few weeks now. will idle a little rough then anything less then full throttle it dies.
I've narrowed it down to master jet, so I usually I just take the boot off the carby hat, open the throttle and stick my hand over the hat.
but today this didn't work!! any ideas? I'm going to pull the carby off and give it a clean but I'm not hopeful.
Post Posted: Wed Mar 13, 2013 8:46 pm
All sorted was full of silt and rubbish.
Post Posted: Mon Mar 18, 2013 6:22 am
Happening again. Anyone got any ideas
Post Posted: Mon Mar 18, 2013 10:01 am
New fuel filter(s)? Clean your tank out?
Just thinking out loud
Vehicle: '93 1.3 Suzuki sierra soft top
Post Posted: Mon Mar 18, 2013 1:38 pm
>Swap cords 1 and 4 on dizzy
> start and rev to 2.5
>let it die down
>rev to 2.5 again and jet will back fire (best you have the cap off the carby)
Sounds like a similar problem to what mine had. this didn't fix mine but it may work for yours. i ended up cleaning out the entire carby. ran fine for about half an hour then went back to running like shit.
Just got a modified weber instead.
Post Posted: Mon Mar 18, 2013 2:55 pm
Best thing I ever did to my carby was stripped all the non essential parts off it, like the auto choke and idle up, and stuck a $2 filter between the pump and inlet on the carby and I havent had to touch it since, which is going on 4 years now. Do a search on here for Sheps carby fix.
Post Posted: Mon Mar 18, 2013 7:16 pm
Just put a new/second hand tank in and it was fairly clean.
New filter. Doesn't have any of the silly things on it.
mechanic friend of mine suggested its over fuelling heavily, hence its flooding except for when at full throttle?? seems plausible to me as it does smell like its running extremely rich.
Vehicle: crazy zook
Post Posted: Mon Mar 18, 2013 7:55 pm
Clean out carb. . Replace fuel filter.. put in a little motorbike fuelfilter ( from any sprint or repco ) just before the carb.
Common problem on the sierra..
Post Posted: Tue Mar 19, 2013 4:48 pm
So from what I can tell ur all right. Where the fuel line goes in keeps getting shit in it and that's when it runs like a pile.
:D thanks for all the help will get a fuel filter and should fix the problem
Post Posted: Sat Mar 30, 2013 7:16 pm
soo the filter fixed the problem for a few days until it melted.
Ive decided to pull the carby down and rebuild it.
ordered a kit and im just going to do it bit by bit over the next week.
i found an exploded diagram on google but its not really that good.
so if anyone has any tips or links to a guide would be great.
First time ive rebuilt a carby so should be exciting.
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Mar 30, 2013 8:18 pm
I rebuilt one it ran well I just cleaned it up and replased all the parts and blew everything out
Post Posted: Sat Mar 30, 2013 11:01 pm
How did the filter melt, mine has been on there for a few years now.
Post Posted: Sun Mar 31, 2013 10:37 am
was a plastic one. probably too close to the rocker cover.
it just softened enough for the barb to bend over and kink and block the fuel.
Post Posted: Sun Mar 31, 2013 11:01 am
Shit, same place mine is between the carby and rocker.
Post Posted: Sun Mar 31, 2013 11:32 am
yeah might have to get a metal one
Users browsing this forum: No registered users and 89 guests
