Ive tried searching but cant find any info how to remove a jimny gearbox. Ive got every thing undone, but i cant seem to get the box far enough back past the cross member to Alow the bellhousing to clear the clutch. Does any one know the best way to remove a non vvt jimny gearbox .
Joined: Mon May 30, 2011 9:28 am Posts: 2233 Location: Townsville
Posted: Sat Apr 27, 2013 5:54 pm
yeah i've heard some people need to pull the engine forward a touch with straps or something too! Let us know how you get on, I may need to do my nonvvt soon too!
remember if you have enough access to the breather on the gearbox, chuck a hose on it! this will probably be the only chance you get to put a decent breather on there.
Joined: Sat Mar 24, 2007 10:30 pm Posts: 1052 Location: MORNINGTON. VIC
Posted: Sun Apr 28, 2013 5:23 am
push the gearbox to the rear and remove the clutch. gearbox will then just drop out. refitting is the reverse. I used a mirror and torch to align the splines with the spigot bearing
Users browsing this forum: Google [Bot], jono165 and 74 guests
