| Author |
Message |
Xtreme
Vehicle: hkbjk
 Posted: Thu Jul 11, 2013 5:44 pm |
I have put on 31x10.5 R15 with -13 offset rims on my 99 Jimny. Arches are trimmed, nothing hits and it has a 2inch OME kit int it. The engineer has said that because the lift due to the wheel diameter increase puts it 6mm over the 50mm allowed that it will require a swerve test to get engineered.
The swerve test is a double lane test swerving through cones out to the other lane and back again within a prescribed distance without knocking over any cones and without any wheels lifting.
He has mentioned that many older hilux and pajeros fail it, and with the jimnys high COG it will probably have trouble as well. The test is performed at 110km/hr.
He did say that the lift because of the stiffer springs should help.
Has anyone had this test done with a similar set up and if so how did you go?
tim80z
Joined: Tue Dec 14, 2010 8:09 pm Posts: 722 Location: Parkes NSW
 Posted: Thu Jul 11, 2013 7:11 pm |
Get a different engineer.
I used Treeve in Orange for my lane change test and it passed with ease. Treeve does all testing at 80km/h which is all that the RMS requires.
On the test day he mentioned that the test used to be done fully loaded at 100km/h. Under those conditions he was able to get a fully loaded 5inch lifted Surf through after a few attempts.
Xtreme
Vehicle: hkbjk
 Posted: Thu Jul 11, 2013 7:26 pm |
Ok thanks, a long way for me to go as I am located on the central coast, but if you have his number handy could you pm me and ill give him a call and see what he thinks my chances are.
tim80z
 Posted: Thu Jul 11, 2013 7:36 pm |
jono165
Joined: Thu May 27, 2010 12:01 pm Posts: 834 Location: Melbourne
 Posted: Thu Jul 11, 2013 8:26 pm |
If you don't mind me asking, myself and a few others down here are going down the engineering route, what sort of prices are you guys charged to do the lane change test?
I've been quoted $2000-3000 dependant on how many cars they can get on one day with no basis for comparison I'm just curious to find out what it costs others and if its reasonable.
Xtreme
Vehicle: hkbjk
 Posted: Thu Jul 11, 2013 8:30 pm |
So far I've only had one quote at 1200
tim80z
 Posted: Thu Jul 11, 2013 8:49 pm |
The engineering cost me $900 (lift, tyres, wheels and 1.8 conversion) and the lane change test cost another $770 on top of that.
Daz7
Joined: Mon May 31, 2010 3:04 am Posts: 242 Location: Sydney
 Posted: Thu Jul 11, 2013 8:56 pm |
Fwiw Treeve is one of the more switched on engineers in NSW so worth the trip.
Matthew
Joined: Mon Jun 15, 2009 11:30 pm Posts: 472 Location: S.E. Melbourne
Vehicle: SWB Sierra
 Posted: Thu Jul 11, 2013 9:14 pm |
Why can't we have prices like that in Vic
atari4x4
 Posted: Thu Jul 11, 2013 9:18 pm |
Matthew wrote: Why can't we have prices like that in SA  ditto
JrZook
 Posted: Thu Jul 11, 2013 9:22 pm |
Why can't we even have that option in QLD.....
jono165
 Posted: Thu Jul 11, 2013 9:23 pm |
Matthew wrote: Why can't we have prices like that in Vic  I reckon, i'm going to do a bit more shopping around if it comes to needing to do the test. Tim mentioned having 8-9 cars on one day which would substantially reduce the price.
atari4x4
 Posted: Thu Jul 11, 2013 9:29 pm |
JrZook wrote: Why can't we even have that option in QLD..... but they seem to hand out mod plates for anything & everything in QLD
tim80z
 Posted: Thu Jul 11, 2013 9:34 pm |
Treeve does all his testing together, lane change tests, brake tests, etc and on a whole range of cars. I think he runs 1 or 2 test days each month and they are done on the runway at Cudal airport. Here's a few pics from the test day:   - Tim.
BlueSuzy
 Posted: Thu Jul 11, 2013 9:36 pm |
Looks like the Mirage Failed the test  I will be hopefully going through this soon
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Fri Jul 12, 2013 8:24 am |
atari4x4 wrote: JrZook wrote: Why can't we even have that option in QLD..... but they seem to hand out mod plates for anything & everything in QLD  For allowable mods. But we can't prove that larger than allowed tyres have not effected the way the car drives and therefore gain engineering approval.
atari4x4
 Posted: Fri Jul 12, 2013 9:51 am |
Zook_Fan wrote: atari4x4 wrote: JrZook wrote: Why can't we even have that option in QLD..... but they seem to hand out mod plates for anything & everything in QLD  For allowable mods. But we can't prove that larger than allowed tyres have not effected the way the car drives and therefore gain engineering approval. ahhh cool, that old chestnut still around up there.
