It is currently Tue Nov 03, 2026 9:28 am
Vehicle: 92 model Sierra/Vitara 1.6Efi
Post Posted: Sun Sep 08, 2013 7:42 pm
Hi,
I have a '92 Sierra soft top. What is the fuel tank capacity on these? I have it on the farm I work on and don't get to fill it from a bowser. I need to put a 20 litre drum of fuel in it nearly every couple of days, and don't drive more than 40 odd kilometres over that period. Sometimes it fills it,... sometimes it don't.
Just wondering?
Cheers,
Ted.
Vehicle: '94 suzuki maruti
Post Posted: Sun Sep 08, 2013 7:45 pm
assuming no dents in the tank, 40L.
oh, and dont trust the gauge. my old SWB's gauge used to read full for the 1st 100km, then over the next 50km drop to 1/3 of a tank, then sit there for another 100 then drop to empty.
Post Posted: Sun Sep 08, 2013 8:55 pm
Mine just reads full all the time. It has a coily dash fitted, but not by me. Nothing works except the oil light on start up. :x
Post Posted: Mon Sep 09, 2013 10:34 pm
Ted, you're running a Vitara engine so you've probably got a Vitara tank as well, from memory it should hold a few litres more than the 40lt Sierra tank.
If your tank is dented, it can be popped out with compressed air.
The fuel gauge not working might be the sender, easily fixed, see this thread.
viewtopic.php?f=17&t=4140
But the above won't solve your fuel consumption problem, should be getting 100+km from 20lt, could be engine related, this thread is about V6s but might be of help.
viewtopic.php?f=5&t=41728
Vehicle: WT sierra, GU CRD
Post Posted: Mon Sep 09, 2013 10:48 pm
Not trying to be smart, but what makes you think he has a vit tank? IFAIK they take a bit of effort to fit, and is why I didn't pull one from the wreck with the G16b. Coily tank is where its at.
I love ZD30. :)
Vehicle: SJ70 1993
Post Posted: Tue Sep 10, 2013 8:44 am
both my sierras #70lt tank #carby tank both gauges when full read empty till 1/3 then was accurate till empty
Post Posted: Tue Sep 10, 2013 10:50 am
I was guessing you would run an efi tank with an efi engine, could be wrong (and stop being smart :wink: )
Post Posted: Tue Sep 10, 2013 11:15 am
You are very likely to be wrong.
Almost all conversions use a coily tank. If not, it's usually an external fuel pump. Vit tanks are far from bolt in.
Vehicle: 85 ' Drover
Post Posted: Tue Sep 10, 2013 12:12 pm
Maybe we should let the guy who actaully owns the car comment on what tank he has?
Post Posted: Tue Sep 10, 2013 3:04 pm
because that solution is too obvious
Post Posted: Tue Sep 10, 2013 3:29 pm
. . . and the tank is not the actual problem, it's using 20lt to travel 40km, a 1.6 on 31s with 6.5 gears that is only used on the farm should be doing much better.
Post Posted: Tue Sep 10, 2013 3:35 pm
I had an arguement with some woman over what my name was once. She told me I was lieing, I eventually gave up and admitted that my name mustn't have been Mark.
steve125 wrote:
. . . and the tank is not the actual problem,.
You're the one whom commented on tanks to begin with.
Sounds like fuel is leaking straight out with that consumption. I don't know efi at all, but would O2 sensor and VSS be places to start looking? Wheel bearings poo-ed out? Flogged bearings in drive line, dragging brakes could all be factors
I love ZD30. :)
Post Posted: Tue Sep 10, 2013 5:04 pm
Terrain/duties
Post Posted: Tue Sep 10, 2013 5:47 pm
I know of 3 conversions that have used vit tanks, the mounts aren't overly complex. In any case a swb 1.6 vit tank is 42L so its practically the same as Sierra anyway.
Post Posted: Tue Sep 10, 2013 6:25 pm
^^Gwagen cab off builds?
I agree with sideways. Coily tank or Dak Dak pump is how it is done 90% of the time. Some of us who don't wanna fab tank mounts when original Suzuki equipment that will work is available.
I love ZD30. :)
Post Posted: Tue Sep 10, 2013 6:50 pm
2 of them, yes, and I'm sure there are others around. I think Joe might have even built a few with vit tanks too, but I do agree that coily/external pump is more common.
My point was more the OP has a tank of about 40L, I don't know of any non Suzuki tanks that will fit in a swb Sierra except a long ranger and I don't believe the larger vit tanks fit between the rails.
Post Posted: Tue Sep 10, 2013 7:27 pm
Sorry guys,..I have been offline while you were all trying to help. :lol:
I'm not sure what tank is in the beast, as I just bought it off a young bloke in Brissy about four months ago and have spent most of this time fixing broken stuff. He had given it a fair hiding. I don't know jack shit about these little beasts as I am really a diesel 'cruiser guy. Though I bought the Zook to get around some of the bad arse mountain tracks we have on the farm I work on. Two Landcruisers, one Nissan Patrol, and two Hilux utes couldn't get up one track in particular. The Zook in low second with the Trailcreeper kit crawls up there with no problems. Its running 31" Wrangler Kevlar MT's on steel wheels. Its a WT Sierra. It will pull 120 k/h in third high on the black top (thats GPS speed) and I run out of road up there to do fourth. :mrgreen: I'm lovin it at the moment, and this forum has been great to help sort some shit out.
Yeah,..fuel economy is bad, but I suppose it could be the terrain. Theres bugger all flat country. On the farm itself, I never get out of second high, and am mostly in first, or low range. (hence why I fitted the 6.5 gears).
I will check out the sender guage this weekend.
Thanks guys,
Ted.,
Ps, I thought I should ad that this motor seems to run really rich, and a lot of blue smoke blows out of the exhaust. Being an EFI, I have no idea. I have cleaned the hotwire in the air box, and used carbi cleaner inside/outside the intake etc, to no avail. Nothing seems to work on the dash, except the oil light, though it has a kick arse computer in the cab. :roll: I really wish it had a carby.
Vehicle: Suzuki/Sierra/1988 SJ50 HiTop
Post Posted: Tue Sep 10, 2013 10:37 pm
No you don't...
Vehicle: 4wd
Post Posted: Tue Sep 10, 2013 10:42 pm
Coily tank is an efi tank :roll:
Watch out or you'll get sued.
Post Posted: Tue Sep 10, 2013 10:58 pm
lol at this thread. :?
Vehicle: Ford Maverick 4.2 Diesel
Post Posted: Tue Sep 10, 2013 11:15 pm
lol at loling
Post Posted: Tue Sep 10, 2013 11:31 pm
lol at loling at loling
Post Posted: Wed Sep 11, 2013 5:25 pm
O2 sensors could be stuffed if its running rich
would a blocked return line cause over fueling
Post Posted: Thu Sep 12, 2013 7:50 pm
Mate what is an O2 sensor?
Post Posted: Fri Sep 13, 2013 6:44 pm
Sensor thay screws into extractors
if u can take it to get someone to have a look with a scan tool they will be able to check
Post Posted: Mon Sep 16, 2013 7:28 pm
OK thanks :P
Users browsing this forum: No registered users and 65 guests
