It is currently Mon Nov 02, 2026 11:04 am
Vehicle: 2008 JB turbo diesel
Post Posted: Tue Sep 24, 2013 7:23 pm
Hi all,
I'm currently looking putting a dobinson 40mm lift in my grand vitara and I am wanting to grade my tyres as well to some all terrain ones but not sure on what size to go to. I am looking at 245/65/17 but my issue is that what the heck do you do with the spare as I do t believe it will fit in the cover. What has everyone else done when they have upgraded their tyres. Obviously you can't use a odd size tyre when ya get a flat as you will start damaging cv shafts and gearbox etc.
Good to hear your feed back
Post Posted: Fri Sep 27, 2013 11:04 pm
Might be a case of ditch the cover?
As long as the bigger tyre fits on the door, be done with it!
Rgs, Michael
Post Posted: Sat Sep 28, 2013 9:04 am
Just run it without the cover, the inner part is easy to remove, you may need to space the tyre away from the body with a couple of thick washers over the studs.
Vehicle: 11 GV3 diesel
Post Posted: Sat Sep 28, 2013 10:50 am
I ditched my cover and sold it on gumtree for the mods fund. Also as steve said put some washers in as it will scrub ever so slightly.
Post Posted: Sat Sep 28, 2013 5:34 pm
We have done the same..... managed to squeeze a 225/75/16 inside the cover but it was so tight it took ages to get it off.
Ditched the cover and its all good.
Users browsing this forum: No registered users and 85 guests
