It is currently Sat Oct 24, 2026 10:33 am
Vehicle: Suzuki Jimny 2004
Post Posted: Mon Apr 27, 2015 6:27 pm
So something has obviously stuffed up in the vacuum hubs as the 4wd light flashes. So was just wondering where the best place to buy manual locking hubs is?? TIA
Vehicle: Suzuki Jimny 2009
Post Posted: Mon Apr 27, 2015 7:37 pm
You can fit Sierra hubs and you can either grind off the ring or use the Ben T adaptors. If you use the adaptor you can still go back to the original hubs if you ever wanted to do that. You also need to then block off both the vacuum lines going to the front hubs. That way the light will stop flashing. This is probably the most common modification for a Jimny with vacuum hubs.
Post Posted: Mon Apr 27, 2015 7:54 pm
Ok, what about the avm hubs, where can I get them?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Apr 27, 2015 8:41 pm
http://www.jimnybits.co.uk/shop/jimny/d ... od_33.html
terrain taimer in au also stock them.
Users browsing this forum: No registered users and 94 guests
