It is currently Fri Oct 23, 2026 7:58 pm
Vehicle: Vitara 1.6
Post Posted: Mon Aug 24, 2015 8:25 am
So my vit has been okay for a while since the wiring was redone to the battery.
Now another problem. Intermittent cant start. It is not fueling based on the tests we ran.
Spark is strong.
3rd last time it started ir ran on half cylinders for about 5 seconds before working fine for a 3 hour drive.
A mechanic friend of a mechanic friend says it is most likely the cam or crqnk angle sensor based on symptoms.
I hav a dizzy so would inly hav the latter afaik.
I thought it would b at the front of the sump but nothing there.
if womebody knows where it is i would appreciate it.
Car is 3 hours away now had to take my parents gv back to work.
Thanks
Sent from my SM-G900I using Tapatalk
Post Posted: Mon Aug 24, 2015 10:06 am
No crank angle sensor on a Vitara g16b- camshaft only via the dizzy.
Post Posted: Mon Aug 24, 2015 1:32 pm
If I'm not mistaken there is a "noise filter" that also provides ignition feedback to the ECU, and if that fails, the ECU does not "see the spark" and kills the fueling.
http://www.rhinopower.org/diag/cel.html
Insert the diagnostic jumper, check for failure codes, crank the engine over with the jumper in place and then without switching the ignition off, check the codes again - it's either a 41 or a 42
Users browsing this forum: Google [Bot] and 119 guests
