If I'm not mistaken there is a "noise filter" that also provides ignition feedback to the ECU, and if that fails, the ECU does not "see the spark" and kills the fueling.
Insert the diagnostic jumper, check for failure codes, crank the engine over with the jumper in place and then without switching the ignition off, check the codes again - it's either a 41 or a 42
Users browsing this forum: Google [Bot] and 148 guests
