It is currently Thu Oct 22, 2026 10:48 pm
Post Posted: Fri Sep 18, 2009 9:37 pm
This is most likely one of the most stupid questions ever, and i apologise. is there a difference between a NT and a WT body or does a WT just have wider flares? The reason that i ask is that im looking at buying a windsreen surround to fit to my 85 1.3 LWB sierra.
Post Posted: Fri Sep 18, 2009 9:43 pm
NT and WT 1.3 bodies are the same, just wider flares. 1L bodies have a smaller trans tunnel.
Post Posted: Fri Sep 18, 2009 9:45 pm
Awesome. thanks heaps. so it wasnt such a stupid question after all.
Vehicle: 75 Cruiser
Post Posted: Fri Sep 18, 2009 10:04 pm
yerp mostly the same...
although the only difference i can think of is that in the early NT bodies, they didn't have holes for retractable seatbelts, and then later they just had a drivers side hole, then later in the wide tracks they had rectractable seatbelt holes on both sides.
useless information No. 363 :)
Post Posted: Fri Sep 18, 2009 10:57 pm
does this mean that a NT drover body can be fitted to a WT chassis ??
Post Posted: Fri Sep 18, 2009 11:46 pm
Can't see why not flexedup88
Post Posted: Sat Sep 19, 2009 1:10 am
well that would certainly make a WT conversion alot easier i can buy a wreck from auctions strip it and build up a wicked chassis and running gear then just transfer the body on over a weekend :D
Post Posted: Sat Sep 19, 2009 1:35 am
there is a difference between the windscreen surrounds, wipers, arms and mechanisms are different. NT have a shorter gap between the wiper arm and the windscreen squirter. WT have a bigger gap between the wiper and the squirter.
Having said that if the surround is complete including arms and mechanism's then they are interchangeable as complete items but if the surround is bare then it will need to be the same as the one with these parts in it.
David
Zuki
Suzuki Sierra 1990 Hardtop
Now just drive i
Vehicle: MY2019 Jimny
Post Posted: Sat Sep 19, 2009 3:01 am
Aren't spring mounts different as well?
Post Posted: Sat Sep 19, 2009 1:25 pm
I believe they were talking about the bodies. :oops:
Post Posted: Sat Sep 19, 2009 4:16 pm
True, but if it were me I would stay with the NT chassis and spring position and fit WT diff housings, which will make it a much better off road vehicle with better flex and articulation
Post Posted: Sun Sep 20, 2009 10:11 pm
Details, details...
8)
Users browsing this forum: Google [Bot] and 181 guests
