| Author |
Message |
cyprus73
Vehicle: 2000 Suzuki Grand Vitara
 Posted: Thu Apr 21, 2016 9:21 am |
Hi All.
I have just purchased a 1988 Suzuki Sierra with a g13a motor. As this is for my son who is on his "P" the block needs to stay.
What I'd like to do for a cheap performance upgrade is run the g16a head on the g13a block. My research tells me I need the following:
g16a head, head gasket, cam, inlet manifold, dizzy, timing chain cover and timing chain tensioners.
Is this correct?
Do i need anything else and is this a straight bolt on or do I need modifications?
Appreciate your assistance.
Chris.
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Thu Apr 21, 2016 9:47 am |
Wont make any difference whatso ever Its a straight bolt on because its the same head as the 1.3
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Thu Apr 21, 2016 9:49 am |
I doubt you'll see much (if any) performance gain. The g16A has slightly larger valves but that's really it.
The g series doesn't use timing chain- it's a belt driven motor. There are some differences in belt width and profile between variants- you'll need to be aware of that.
You shouldn't need a new tensioner or timing belt cover. Manifolds are interchangeable. Fuel pump mounting boss is different so the pumps aren't interchangeable.
cyprus73
 Posted: Thu Apr 21, 2016 9:53 am |
Thks All.
Most of the read ups said there was an improvement. Wont waste my time on it then. So what would be an easy cheap upgrade? It already has extractors on it.
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Thu Apr 21, 2016 10:05 am |
Many people <3 every mod they make, while being unable to quantify their improvements. Some who spend big upping the g13a and keeping it carby, later admit it's not worth the cost/effort.
Besides going to efi, there are no simple performance gains that are worth while.
I have fiddled around with the g13a a little, bastardised a g16 with g13 stuff, ran a g16a for a while, played heaps with the carby, ran a corolla carby for a while, ran extractors and torque cam, ran 98 and advanced the timing, stupid k corolla motor. Seen a few fully reconditioned and not last. Opening a suzuki engine is best avoided. They never seem to last once opened. Generally it all sucks and was a waste of money compared to vit/baleno efi
A healthy stock engine, with carby up to spec, is about the best performance/cost Sure it sucks, but you can save the coin and efi it later.
jdk81
 Posted: Thu Apr 21, 2016 10:07 am |
Sorting out the gearing is about the best performance mod you can make, and then just maintain the car properly.
cyprus73
 Posted: Thu Apr 21, 2016 10:22 am |
Thks jdk81.
Looks like my son will live with the g13a until he gets off his "P" Appreciate all your help guys.
Gwagensteve
 Posted: Thu Apr 21, 2016 10:40 am |
What was the reasoning behind the improved performance of a g13 with a g16 head? Different cam profile? Bigger valves?
Personally the g16A is my least favourite Suzuki motor. It's lazy.
cyprus73
 Posted: Thu Apr 21, 2016 11:08 am |
Not sure Gwagensteve. All the read ups suggested better performance, bigger cambers, cam opens up for a bit longer and carbie is bigger
MrRocky
 Posted: Thu Apr 21, 2016 11:44 am |
Skim head to bump compression up 3/4 of a point was the best seat of pants mod i have seen on a 1.3. Downside is 98+ octane only
cyprus73
 Posted: Thu Apr 21, 2016 1:40 pm |
Is the 13a and 16a block the same?
MrRocky
 Posted: Thu Apr 21, 2016 1:41 pm |
G16 is about an inch taller
MrRocky
 Posted: Thu Apr 21, 2016 1:42 pm |
And slightly different bellhousing pattern meaning you need a $200 adaptor kit to bolt it up to the 1.3 gearbox
Rhinoman
Joined: Mon May 16, 2011 7:03 pm Posts: 686 Location: Brinkworth, England
 Posted: Mon Apr 25, 2016 6:01 am |
Gwagensteve wrote: What was the reasoning behind the improved performance of a g13 with a g16 head? Different cam profile? Bigger valves?
Bigger valves, bigger ports, slightly more cam duration.
THE_DICTATOR
Vehicle: Suzuki Jimny
 Posted: Mon Apr 25, 2016 7:18 am |
G13b or G13bb and EFI will be a real performance upgrade
_________________ hillbilly 2 wrote: And this ^^^^ clown is why auszookers will never be taken seriously
