It is currently Mon Oct 19, 2026 4:11 pm
Vehicle: Suzuki Grand Vitara 04 manual
Post Posted: Mon Apr 25, 2022 8:59 am
Good morning all.
After coming home from a week ar Fraser Island I noticed a new sound from the engine bay. Concidering the sand and salt it sounded too me like a idler or accessory bearing had failed or got sand stuck in a pulley somewhere.
I sprayed them all with no change. The sound has now intensified and using the old screwdriver stethescope the sound is the loudest right on the front of the cam cover.
Any suggestions as to what's wrong? The sound increases with revs.
Post Posted: Mon Apr 25, 2022 11:19 am
I would suggest you remove the serpentine belt and run the engine without it - 30~60 seconds should be enough for you to determine if the noise is present - if it is, it'll be something in the timing chain area, if it stops it's external to the engine which, in my opinion is more likely.
Post Posted: Mon Apr 25, 2022 11:29 am
Great tip thanks.
Post Posted: Mon Apr 25, 2022 1:16 pm
Thanks
The engine is noisy but I removed the top idler and its definitely causing some of the noise. I'll swap out and do the auto tensioner at the same time
Users browsing this forum: No registered users and 224 guests
