It is currently Mon Oct 26, 2026 3:00 pm
Post new topic Reply to topic  [ 221 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Post Posted: Mon Mar 24, 2014 7:23 pm
This is a great read and seems to reinforce some ideas that I'm using in my new build which is lj81 chassis and tub for it's small physical size, a g16b with aw4 auto adapted to a 5:1 atlas transfer with heavily shaved 60 series diffs with rear steer.
I went with the atlas as I felt the sierra case would be on borrowed time on 40's and I wanted the weakpoint to be the chromo axles or traction and the other point is if you feel the car is too light to generate enough traction then it's easy to add weight in the tyres
Post Posted: Mon Mar 24, 2014 8:36 pm
Not good Dan?
Post Posted: Mon Mar 24, 2014 8:46 pm
tanshi wrote:
Not good Dan?
I reckon its dumb, but its subjective.
Look on Outers, theres a thread on there with Marcus the homo wanting to use air bags to defy gravity and float over obstacles past the 5th layer of gravity.
Post Posted: Mon Mar 24, 2014 8:49 pm
SierraDan wrote:
I reckon its dumb, its subjective.
Care to elaborate?
Post Posted: Mon Mar 24, 2014 9:02 pm
JrZook wrote:
Care to elaborate?
Post Posted: Mon Mar 24, 2014 9:35 pm
LOL not that thing! Elaborate as to why you think the concept is dumb..
Post Posted: Mon Mar 24, 2014 9:59 pm
If my car was trying to level the cab and puff air and be all air bag like while im trying to drive, i'd burn it.
Makes sense more so in ruts maybe, but if you were to do it in a car that actually drove stuff like at TT, it would make the car worse in my opinion.
But, its my opinion not yours, doesnt worry me.. One less competitor to worry about on the leaderboard :D
Chuck some air shocks in it, and wheel it.
P.S. :lol: http://www.outerlimits4x4.com/viewtopic ... fy+gravity
Post Posted: Tue Mar 25, 2014 4:31 am
Pretty sure it's been tried, unsucessfully, like traction control. (at TT I mean)
Post Posted: Tue Mar 25, 2014 4:51 am
Did he even drive it before ripping it all out
Post Posted: Tue Mar 25, 2014 6:03 am
Pretty sure there was a 40 series there he first year with auto levelling airbags. In don't think it's a worthwhile advantage. The problem with all those systems is that they seem to make the car unpredictable or counterintuitive when the car is (for example) close to rolling and at full flex, or under power.
Rock buggies in the US went through this evolution in the late 90's/early 00's where suspension was getting more and more complex but I don't believe any of those cars work better than 4links/air shocks/swaybars/suck down winches for an event like TT.
Post Posted: Tue Mar 25, 2014 7:25 am
Didnt that pootrol ute on 93" rubber have forced articulation aswell? A little different, but same territory, how did that go?
Post Posted: Tue Mar 25, 2014 7:58 am
theres a feee on the line up with hydraullic or forced articulation. But thats manually controlled.
Post Posted: Tue Mar 25, 2014 8:04 am
If you mean Phil Noble's GU with the 49" iroks, it has hydraulics. These are user operated so not what I consider "forced"- in the case of the dobbin struts in that car the suspension remains sprung at all times.
They're cool but I don't think they are required for success.
Post Posted: Tue Mar 25, 2014 8:08 am
As far as width goes, how narrow is too narrow? i mean its cheap in penalty points to hook a strap up and if the car is light enough you could literally man handle it on a strap.
it is also free to rock stack so why do more people not stack more. is it a stigma thing about stacking?
Post Posted: Tue Mar 25, 2014 12:29 pm
I stack every track.
Its fun to not stack on social trips a try and find that perfect line.
But in a comp, you're limited on time and penalised for multiple attempts/reverses you have to get it right the first time.
Post Posted: Tue Mar 25, 2014 3:44 pm
Stacking seems necessary but there aren't always small enough rocks that a normal person can physically lift. If you run a course down the order a bit some of the stacking's already done but then some stacked rocks are kicked out and tumble all the way to the bottom of the hills. I think a simple, well sorted machine would be the go and sometimes the most capable machine, or driver even, doesn't win. Lots of stuff breaks and strategy plays a big part. I think it was '05 when Mick got the Mogrover to 2nd, he purposely called a couple of tracks early to avoid damage and penalties, where other guys gave it everything and ended up broken or rolled out of course and lost points. Back then the Mog had simple coils and shocks but the geometry was right. In '08 some other guys had it, put on some coilovers and changed the links, it came home way down the order and last time I saw it it was upside down and on fire. The competition had improved a lot in those few years though and I haven't seen Antunac's new "cruiser" but fron photos and what people say it's on a whole other level nowadays.
Post Posted: Tue Mar 25, 2014 4:47 pm
Pete rebuilt for Cole and Shannon?
The new owner also couldn't drive by the looks of it... so was probably fighting two battles at once
Post Posted: Tue Mar 25, 2014 5:28 pm
Shannon wont be coming by the looks. Double booked.
Post Posted: Tue Mar 25, 2014 7:16 pm
Long trip out to dodge cones tho, so fair enough.
Post Posted: Wed Mar 26, 2014 3:24 pm
Why a 4 link Steve? What other suspension characteristics would you be shooting for? High roll centre? Low or high antisquat?
Post Posted: Wed Mar 26, 2014 7:22 pm
High roll centre.
A not too much or too little squat in the rear, we tried as much as possible to get the front to "squat" to help with climbing, so far so good compared to the old 3link that wasn't much chop (geometry wise not because it was a 3link), sway bar in the rear, front suck down winch.
Working very nice so far, great balanced setup.
Post Posted: Wed Mar 26, 2014 7:37 pm
Bingo. High rear roll centre FTW.
Post Posted: Tue Apr 01, 2014 6:27 am
So who went and took notice of the different setups?
What are your thoughts??
Post Posted: Tue Apr 01, 2014 7:08 am
What were your thoughts on your setup?
Post Posted: Tue Apr 01, 2014 10:04 am
I didn't have any time to suss everyone's cars out.
Looked like you were hating your wheelbase a bit Mick?
The new setup in Jasons car blew me away.
Post Posted: Tue Apr 01, 2014 10:13 am
Just saw a FB post by the guys from the proclaimer saying how the tracks were too narrow and zooks and narrow buggies are the only things that did really well.
seems like this thread is a bit justified :D
Post Posted: Tue Apr 01, 2014 10:29 am
Pip and Tims car- TJ/U4000 mog axles- hardly narrow
Pete's 40/416 mog axles- hardly narrow
Barzook- dobbin portal 9"- narrower than first and second, but wider than we're talking about in this thread.
The proclaimer didn't fit last year. Funnily enough it didn't fit his year either.
Post Posted: Tue Apr 01, 2014 10:36 am
yeah i know, just thought it was funny.
Good to see some of the videos with more track detail this year.
i find it funny that most of the tracks only really seemed to have one really hard point.
not that im say the reast was easy be relativly the ones ive seen had just one pinch point.
Post Posted: Tue Apr 01, 2014 10:38 am
The Proclaimer isn't a competitive/practical car by any means. Its there for the rednecks.
Post Posted: Tue Apr 01, 2014 10:41 am
Mini Wirriba and Rock Garden were the hardest tracks this year.
Timmy did a good job of making the Rock Garden a challenge this year, i enjoyed it.
Users browsing this forum: Google [Bot] and 267 guests
