It is currently Tue Nov 03, 2026 1:06 pm
Post new topic Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3  Next
Vehicle: 95 Sierra Soft top
Post Posted: Mon Dec 06, 2010 4:54 am
rpmwrx wrote:
IN2DEP wrote:
As with all mods there are different ways to go about it.
You can fit 33's with no lift if you are happy to do some panel work.
no i dont want to chop, makes my car look cheap
A virtual lift done properly doesn't look cheap at all... low centre of gravity with chopped guards and big tyres is the new cool...
well looking at jr-zooks build up,
the v lift is pretty good, i didnt know you can go on the indside and do it i thought you chop away from the front bar on wards so its visible to the eye
but that looks sweet, but ive already got the kit in, its sitting in my room so cant do anything about that lol so some one said flat springs or standard springs same shit
Who knows i might put 33" on it later :)
Post Posted: Mon Dec 06, 2010 5:26 am
cool, how much would it cost for someone to do it to a sierra, do you know? if not dw, but thanks for telling me anyway.
virtual lift i mean
Post Posted: Mon Dec 06, 2010 5:45 am
i bought car with spoa, 31' tyres and through the few years i own it i lowerd it down as much as i could. if i had standard car i wouldn't do spoa but chop chop :), virtual lift. jst my 2c. i don't want to gobigger than 31' tyres so to make car more stable with spoa i have big offset rims (-50mm), i bet wheel bearings don't like it, i do however:)
Post Posted: Mon Dec 06, 2010 5:49 am
:rofl:
Post Posted: Mon Dec 06, 2010 5:51 am
IN2DEEP:
If you MUST go SPOA, then use the flatest springs you can find. Fit thw widest offset wheels you can get and think about running currie or anti-rock swaybars. Thats probably the most stable combo for an SPOA rig you can hope for.
EDIT: do you have the weld in SPOA or bolt in?
Post Posted: Mon Dec 06, 2010 6:03 am
Chris ur car was so scary to watch when u got it, way to high .don't forget a good rap bar as well or u will kill ur rear springs
From all the sierras I've seen with spoa I recon the sway bar would be a great idea
Post Posted: Mon Dec 06, 2010 6:09 am
i can tell you me having no experience in 4wd back than it was bloody scary to drive, so bl was first thing i removed. than it was a long way to find optimum spring setup.
i bend 2 sets of rear springs and bought bolt on track bar from low range, i wish i could weld good enough :cry: , anyway, track bar works a treat now.
i wouldn't mind to put a sway bar to see if it makes any difference on the road, but how to make it easy to disconect for off road??
Post Posted: Mon Dec 06, 2010 8:02 am
IN2DEP wrote:
Ive already got the Coversion kit from low range so i just thought 31s was the way to go for sierras ??
Now im confused ??
ooooo.....nasty spoa kit!..............
if you want to run just 31's do not run a spoa.
nothing wrong with a good spoa, but most people and most kits do a pretty piss poor atempt at it.
Post Posted: Mon Dec 06, 2010 8:08 am
^^^ i think you should listen to this guy, he know stuff about things. :wink:
Post Posted: Tue Dec 07, 2010 1:57 am
This is what i got
http://www.lowrangeoffroad.com/suzuki/s ... e-kit.html
http://www.lowrangeoffroad.com/suzuki/s ... t-kit.html
And i got the Full OTS HI STEER (right hand drive kit)
http://www.lowrangeoffroad.com/suzuki/s ... r-kit.html
FATZOOK : When you say flat springs, you mean standard springs right or are there types of springs out there that are flat ??
Post Posted: Tue Dec 07, 2010 3:22 am
be carefull with the ots high steer. some engineers in vic will not allow it to bolt to the brakes. you are engineering it yes?
Post Posted: Tue Dec 07, 2010 4:14 am
the OTS one doesnt look engineerable to me... mine picks up the king pin bolts as well as the caliper and the original steering arm - it also had to be manufactured from a specific steel and contain ZERO welds.
when brian at suzistore made mine he also made a 2nd one at the same time, which is also on his store: http://www.suzistore.com.au/shopexd.asp?id=1363
not cheap though! haha
Post Posted: Wed Dec 08, 2010 3:44 am
well i got told that this was the best kit out there ??? and im not to sure if im going to engineer it, who does that in vic ??
Post Posted: Wed Dec 08, 2010 8:07 am
IN2DEP wrote:
tanshi wrote:
what springs are you planning on using for your SPOA?
OME 1.5 with a leaf removed from all 4 springs or standard OME springs,
I wanted it to be 3 or 4" of lift, yous might not like it but i do, so i dont need lifted springs now with the SPOA, its all ready high enough
Now is that a good idea or bad idea ?????????
why do people use aftermarket springs for a soa?................don't.
Vehicle: I drive your mum
Post Posted: Wed Dec 08, 2010 8:18 am
I'm with you Joe. My spoa uses a mix of standard springs. Works great.
Layto....
Post Posted: Wed Dec 08, 2010 8:28 am
So keep the standard springs then, sweet so all i need is a few more parts to complete the conversion and then ill be set,
I know most of you guys say lift is no good, but i see alot of sierras that look high, so this is my first 4wd so ive always wanted a big tuff looking 4b
Let me see how it gos and let me learn for myself ive listened to all of yous and ive taken it all in, so ill know what im looking for when i take her out, but i think its not a bad setup, but only time will tell
I do know i need more lift then standard ive been stuck that many times on my chassi cause ive got no clearance lol
But like i said before, the kit is brought so theres no going back now, so hope it gos well
Oh and i can only get a -13 offset is that ok or not enough ??
Post Posted: Wed Dec 08, 2010 8:29 am
squishy, sagged, flat leaves are where its at! =) Once you've got that sorted you'll then need some nice stiff shocks to keep it handling nicely on the road too.
Post Posted: Wed Dec 08, 2010 5:37 pm
15x8 with -28 offset, or 15x7 with approx -17 offset are at least what you want.
Layto....
Post Posted: Wed Dec 08, 2010 7:38 pm
I believe you can get 15 x 8 king rims with a -28 offset. These would be perfect...
http://www.kingwheels.com.au/wheels_ste ... page=steel
Or if you want a bigger offset, Procomp Rockcrawler rims are the go... but then your wheel bearings will not like the bigger offset rims...
15x7 5x5.5 (5x139.7) -38mm 2.5" 726 12
15x8 5x5.5 (5x139.7) -50mm 2.5" 726 13
15x8 5x5.5 (5x139.7) -44mm 2.75" 726 13
http://www.procomp.com.au/Default.asp?MenuId=WHEEL_0052
hope that helps...
Post Posted: Wed Dec 08, 2010 9:53 pm
procomp rims are very hard to get right now (in my experience) - i ordered 4 rims in september ad they STILL havent arrived... the factory in the USA cant seem to keep up supply, and im pretty sure the AU importers arent stomping their feet enough and allowing the USA to give AU stuff lower priority.
Post Posted: Wed Dec 08, 2010 9:59 pm
I had the same problem with Pro Comp rims, they said it would be months before i recieved them. I ended up getting some Kings 15x8 in black from Tyre Torque in Croydon, the blokes name is Pete from what i remember, think they were about $80 each or something.
They have a nice offset and look the goods. Hope that helps and good luck.
95 Sierra, SPOA, 33 JT2s, 5.12s.
Post Posted: Thu Dec 09, 2010 4:17 am
Are 15x8 too big for 31s or just perfect ?? cause i can get black kings 15x7 for $89 but wider will be better for me right, or can i jst go the 15x7 and fit 1" wheel spacers ??
Post Posted: Thu Dec 09, 2010 4:28 am
8's are fine.
Post Posted: Thu Dec 09, 2010 4:35 am
Ha i knew you were the same guy who posted up a thread in the past wanting to make a poser-mobile :P . Yea I may look cool but have you checked out your state's regulations in regards to these modifications? It will not look that tuff with a big defect sticker and a fine on it or even worse insurance not covering you because of an illegally modified vehicle but im sure you have already looked in to it.
What sort of terrain do you drive btw? What mods does your vehicle currently have?
In regards to the rim width, wider isnt necessarily better. You are after offset on the rims.
Dan
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Thu Dec 09, 2010 4:45 am
I think your possibly after the wrong thing if you want a big tough Sierra,
They arent big, you will get laughed at, no one apart from zook drivers will ever admit that its cool.
I recently entered my LJ50 into a competition against some bundera's a land cruiser and a hilux. I started the key and every body laughed. blue smoke belching out the back, and slow as hell it crawled up the first hill climb. Peoples heads turned from the other comp tracks going on and more people laughed.
my point is that owning a zook isnt about looking good, tough, its about luving the zook for what it is
I came out with a first place on that track just FYI
Post Posted: Thu Dec 09, 2010 10:30 am
Very, very true :lol:
Post Posted: Thu Dec 09, 2010 8:03 pm
just had to effing brag didnt ya daz... :D
Post Posted: Thu Dec 09, 2010 8:08 pm
i think my bragging made the point well. :)
its just like you dont drive a mini because it looks tough, you drive a mini cos you can corner without slowing down :)
Post Posted: Fri Dec 10, 2010 2:56 am
you drive a mini because you are secretly queer but still like fast cars and have a opps the kenworth parked on me death wish.
or you enjoy the challenge of trying to make every thing electrical operational at the same time and are secretly queer and use the fast little car excuse to hide it :wink:
Post Posted: Fri Dec 10, 2010 6:26 am
8O
Users browsing this forum: Google [Bot] and 96 guests
