It is currently Tue Nov 03, 2026 11:43 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
Post Posted: Sun Jan 09, 2011 6:29 am
My under dash headlight fuses are still there, cos with the relays triggering off the old loom plug you still need them there...
You don't splice into the original loom at all. Its just like you have in that noob-cad drawing there. The only place it joins the original loom is the original headlight plug. I just shoved some blade terminals in there...
I want my old sig back :(
Post Posted: Sun Jan 09, 2011 11:39 am
Ah okay, that's what I thought was shown there. Which means the new looms would be quite short really?
Vehicle: LPG 1.6 Sierra
Post Posted: Sun Jan 09, 2011 12:47 pm
Jaycar has a relay/fuse combo in 15 or 30A - seems pretty intuitive and a good idea. One for hi beam and one for low beam would make issues easy to identify and resolve:
Can anyone help with a schematic for blinkers and park lights? Do they also use the same 30/85/86/87 relay? While the front bumper is off I might as well kill a few birds with one stone and get the wiring right in the first foot of the car.
Vehicle: 93 Sierra
Post Posted: Sun Jan 09, 2011 2:07 pm
Blinkers and parkers really won't benefit from running a new relayed circuit mate ... they're both low current (5W'ish per light from memory) and stock wiring is fine. Just creating more work to do them also with no noticeable benefit and more wiring to go wrong IMO ;)
If you feel the need to upgrade things, go to LED brake lights (with LED flasher to suit). It's been proven that they light up between 0.1-0.2s quicker than an incandescent globe, which at 60kph is 2-3m of wasted braking distance for the person behind you. A worthwhile mod.
Post Posted: Sat Jan 15, 2011 5:13 am
I just got a set of these bad boys off ebay. So I gotta run a 6mm line from the battery to the relays? That seems pretty hardcore.
Also what's legal/illegal in terms of brightness? What colour bulbs make for the best night driving?
-- Also are the stock sealed headlights rated at 55w/60 or lower?
Post Posted: Sat Jan 22, 2011 12:22 am
So the original headlight looms are separated into left and right... does it matter which side I use to trigger the relays?
Vehicle: Daisy
Post Posted: Sat Jan 22, 2011 12:27 am
Shouldn't do, why the hell are they separate? You could always trigger one relay from each so you'd never lose all your lights?
Also as far as legal, I thought I read somewhere that it has to be the same type of light, i.e. you can't retrofit HID lights if you didn't have them in the first place or something like that.
Post Posted: Sat Jan 22, 2011 12:43 am
The headlights are fused for left and right looking at the stock fuse box, so i'm guessing the wiring runs into the engine bay based on this separation??
I got some Phillips something or other +50 globes (@55w/60) which are legal - nothing too outrageous. But i'll wire things up so 90w/100 bulbs are a possibility down the track if I choose to further upgrade.
Post Posted: Sun Jan 23, 2011 5:38 am
OK, wiring complete and lights should now be at full output.
Will I need to weatherproof the relays/fuses at all? Not for river crossings, just for rain :)
Post Posted: Sun Jan 23, 2011 6:26 am
:no: :P
Post Posted: Wed Jan 26, 2011 11:09 am
Where's the best place to run a 6mm 12v line through the firewall?
Both my loom grommets are full to the brim and seemingly don't want to budge for one more wire...
Vehicle: LJ80
Post Posted: Wed Jan 26, 2011 5:47 pm
clutch cable grommet ?
Users browsing this forum: No registered users and 294 guests
