It is currently Sun Oct 25, 2026 3:02 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
Vehicle: Suzuki Grand Vitara
Post Posted: Sun Nov 09, 2014 10:30 am
The rear Bilstein shocks are fitted.
Vehicle: Vitara 1994
Post Posted: Mon Nov 10, 2014 7:25 pm
A shock that's near 17mm longer compressed is too long for the application.
Why do you say that? As long as he installs bump stops do don't see an issue. It was mentioned the current springs use spring bind to stop the shocks bottoming out. So as long as he sets up some bump stops to the right length (around 17mm longer than the compressed springs) it sounds to me like he will just gain a whole lot of travel. I.e 17mm sacrifice of upward travel for over 2 inches downward travel.
Post Posted: Mon Nov 10, 2014 7:27 pm
This is also assuming the spring will remain captive.
Vehicle: 04 Grand Vitara, 2.5L, V6
Post Posted: Mon Nov 10, 2014 10:13 pm
Haha yea a heap of down travel on the cal springs will let them pop out. If you extend the top bump stop should be fine.
Post Posted: Mon Nov 10, 2014 10:20 pm
that's all nice & shiney, but i don't like the idea of having the shock shaft exposed... eg inverted shocks? won't take much of a rock to be kick up by the front wheels & trash the shock boot/damage the chrome on the shaft, i don't run boots on my commy shocks but at $25 each i'm not fused. but they're mounted in the conventional way.
were you able to order them so they were like the originals? :?
Users browsing this forum: No registered users and 180 guests
