It is currently Thu Nov 05, 2026 3:07 am
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Wed May 28, 2008 11:38 pm
Bruce.....yep these young whipper snappers just don't understand what is COOL!!!!!
Steve W
Post Posted: Thu May 29, 2008 12:38 am
I hear ya old fella :wink:
Vehicle: Clown Car..
Post Posted: Thu May 29, 2008 1:09 am
lol, can we get the thread cleaned up and the chit chat (this post included) removed please!? Ta :)
Vehicle: '92 Sierra
Post Posted: Thu May 29, 2008 4:06 pm
The whole things chit chat. I'm wonder why its in tech and not just plain chat lol. So far the only useful stuff has been perch redrill, sway bar removal, spring leaf removal, radiator backflush, the rubber pipe lagging for seals was helpful lol....ummmm I think thats it.
Things I've found useful personally
Leaf removal (articulation)
Getting a shroud for my radiator (was overheating big time)
Gabrielle commo shocks (articulation)
Cut off the bumper outriggers (clearance)
Hammer seams (clearance)
Half RUF (a drill, 2 old spring packs, some steel for shackles = cheap to me)
Post Posted: Thu May 29, 2008 5:33 pm
not so much modifications but testing of modifications.....
$20 fuel to drive up the local car park and check your approach angle on honda civics and the like!
Web wheeler extroadinaire
Post Posted: Thu May 29, 2008 10:59 pm
Things never stay on track on forums so get use to it. :wink:
Post Posted: Fri May 30, 2008 10:26 pm
joeblow wrote:
....can of prepsol to wash off said white writing from outside sidewall.......
remember people.....white writing on the inside...
NO NO NO!!!
White writing must always be out people!! Always....
Post Posted: Fri May 30, 2008 10:38 pm
NO NO NO!!!
Bwhahahaha All about the :blingbling: hey mate :wink:
opppppppssssss off track again 8)
Post Posted: Sat May 31, 2008 1:37 am
convert rear door to tailgate
Remove hinges and rear door. bolt hinges to rear body mounts (long arm) sit door in place and latch with original latch. Bend up hinges and mark and drill holes in lower lip of door. Bolt together. add side chains and hey presto drop down tailgate.
pics?Image
Post Posted: Sat May 31, 2008 1:44 am
brake upgrade for sierra and SWB vits.
use LWB vitara front rotors and calipers. Completely bolt on. in sierra you need to trim stone guard and caliper needs to be removed and rotated to bleed properly.
(LWB vitaras have vented discs and larger pads.)
Post Posted: Sat May 31, 2008 2:24 am
Not quite under $20 but still could be done pretty cheap and cheerful
Vehicle: '92 Sierra
Post Posted: Sat May 31, 2008 1:39 pm
Nice B4T!
Post Posted: Sat May 31, 2008 3:38 pm
3/4 elliptic rear,
go to your local suspesion shop, look in there scrap bin for 50mm wide leafs, buy some U bolts... DONE!!
spoa, lux diffs, 2inch suspension, 2inch body, 1.6
Post Posted: Sat May 31, 2008 8:46 pm
Bruce wrote:
NO NO NO!!!
This is what happens when you get out of Brisbane and try using a crappy computer!!!!!!!!!! I posted that straight after Joe on the first page, it finally turns up here 3 days later!!!!!! Whats up with that???!!!!!! I suppose it is a fair way to go from Lowood to Brisbane but a 3 day journey?? Could have walked faster!!
Any way, yes Bruce!!! It is all about the bling :lol:
Post Posted: Sun Jul 13, 2008 7:13 pm
cheap side lights all bits purchased at that hardware place to many countless hours can be spent...
the pics explain better than words, but if you are after details.. PM me or ask away..
and yep.. under $20, and I havnt fallen into any ruts exiting the zook since!
Post Posted: Wed Jul 16, 2008 2:37 am
replace the washer nozel with irragation drip line with big 45 deg spray heads and connect the line line to your wiper arms to clean the mud off easier.
Post Posted: Wed Jul 16, 2008 12:35 pm
That is a bloody good idea! I have been trying to come up with an idea for cheap underbody illumination. I just wonder though, how will the halogen bulbs coe with mud and stuff on them?
You should do a tech write up for those ppl who don't recognise those parts ;)
Post Posted: Wed Jul 16, 2008 4:29 pm
no worries at all with the mud and stuff, i actually used pond illumination lights( about $10 from that hardware place) can go green, red, blue, yellow, white.
Will think bout the right up, certainly easy as hell to do. should have no worries in sourcing the parts.. I did it spontaniously while shopping for cement lol.
Post Posted: Tue Jul 22, 2008 12:05 am
What year LWB Vitara are the rotors and calipers off
Gaz
I Do Shade Sails & Roller Blinds, ect
Post Posted: Tue Jul 22, 2008 12:07 am
Gaz
Should be any year model, as long as it's a LWB. The 2.0 V6 ones are slightly bigger again.
Post Posted: Tue Jul 22, 2008 12:12 am
Thanks Damo
so I am looking for the 4cyl LWB one
Post Posted: Tue Jul 22, 2008 12:19 am
only 1.6 the 2l are different rotor offset
just get the calipers new rotors are as cheap as 2nd hand
Post Posted: Tue Jul 22, 2008 12:31 am
Thanks Royce
Yer I am getting new rotors
You wouldnt happen to have the calipers?
Post Posted: Tue Jul 22, 2008 12:39 am
Zip ties :lol: priceless
Post Posted: Wed Jul 15, 2009 5:02 pm
brake lines of a suzuki swift or holden barina
4inches longer
Vehicle: SJ80
Post Posted: Wed Jul 15, 2009 5:37 pm
Ok. So a brake caliper from a LWB 2.0 V6 Vitara bolts up to the same caliper mount bolt holes as the original Sierra one?
Excellent!
The Grand Vitara calipers are different?
Post Posted: Wed Jul 15, 2009 6:03 pm
4inches longer
Dont do it, buy new ones. mine were 35 each, 100mm longer (sierra wit ruf)
Vehicle: 90 WT ST Locker, Tyres
Post Posted: Wed Jul 15, 2009 10:58 pm
im locking (weld) up my rear diff atm.
think of wat cheap cheap mod to do next, maybe extented shackles (might get a mate to make some) any one got and drawings or plans?
Post Posted: Thu Jul 16, 2009 1:27 pm
4inches longer
my bad. just found out thats a bad idea :?
Post Posted: Thu Jul 16, 2009 3:57 pm
Excellent!
GV are different rotor offset, I think the 2.0 V6 is too but look on the DBA rotors site to see
Users browsing this forum: Google [Bot] and 216 guests
