It is currently Fri Nov 06, 2026 5:49 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Post Posted: Sun Jun 24, 2012 7:30 pm
haha, close 36'' yeah they must like grinders :L
Post Posted: Sun Jun 24, 2012 7:32 pm
Looks like iceland. Bear in mind they build those cars for snow exclusively. Wheel travel and driveline strength aren't required like they are here.
Post Posted: Mon Jun 25, 2012 7:12 pm
yeah i think its a bit of a no brainer to not upgrade axles and stuff with those size tyres
Post Posted: Mon Jul 02, 2012 7:11 pm
people were saying to put 30mm spacers in the rear and 15 at the front and it keeps it level so would it work if the rear was 75mm and the front was 60mm?
cheers
Post Posted: Tue Jul 03, 2012 10:15 am
cheers
no because then you would have 75mm in the rear and 120mm in the front. what ever spacer is fitted, the lift will be double.
Post Posted: Tue Jul 03, 2012 8:32 pm
:shocked: 8) whys that? so if it get 15mm at the front it would still be bbig at the front
cause i have 30mm coils and add 30mm spacer at front then put 75mm coil at rear
Post Posted: Wed Jul 04, 2012 4:28 am
So 30mm coil and 15mm spacer will work in the front with 75mm coil in the rear with no spacer
Post Posted: Thu Jul 05, 2012 7:50 pm
seems weird to me but anyway cheers
Post Posted: Fri Jul 06, 2012 9:23 am
The front is a 2.1 ratio as the spring is only halway along the arm
If u lift it 15mm
The wheel moves down 30
Post Posted: Fri Jul 06, 2012 6:55 pm
ohhhh so that makes sence so thats what shandy ment by putting 60mm at front it'll be 120mm cheers got_bar_work
Post Posted: Thu Nov 01, 2012 10:40 am
these are 38" tires and yeas it is in iceland
Post Posted: Thu Nov 01, 2012 11:46 am
Has the rear doors been cut into
Any chance of some closeups of the rear guards
Post Posted: Thu Nov 01, 2012 3:47 pm
I want to know where the flares are from...
Users browsing this forum: No registered users and 79 guests
