| Author |
Message |
BRAD
Joined: Mon Feb 21, 2011 3:21 am Posts: 563 Location: NSW
 Posted: Sun Jun 24, 2012 7:30 pm |
haha, close 36'' yeah they must like grinders :L
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Sun Jun 24, 2012 7:32 pm |
Looks like iceland. Bear in mind they build those cars for snow exclusively. Wheel travel and driveline strength aren't required like they are here.
BRAD
 Posted: Mon Jun 25, 2012 7:12 pm |
yeah i think its a bit of a no brainer to not upgrade axles and stuff with those size tyres
BRAD
 Posted: Mon Jul 02, 2012 7:11 pm |
people were saying to put 30mm spacers in the rear and 15 at the front and it keeps it level so would it work if the rear was 75mm and the front was 60mm? cheers
shandy92
Joined: Tue Nov 25, 2008 10:30 pm Posts: 5066 Location: perth, Australia
 Posted: Tue Jul 03, 2012 10:15 am |
BRAD wrote: people were saying to put 30mm spacers in the rear and 15 at the front and it keeps it level so would it work if the rear was 75mm and the front was 60mm? cheers no because then you would have 75mm in the rear and 120mm in the front. what ever spacer is fitted, the lift will be double.
BRAD
 Posted: Tue Jul 03, 2012 8:32 pm |
 whys that? so if it get 15mm at the front it would still be bbig at the front cause i have 30mm coils and add 30mm spacer at front then put 75mm coil at rear
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Wed Jul 04, 2012 4:28 am |
So 30mm coil and 15mm spacer will work in the front with 75mm coil in the rear with no spacer
BRAD
 Posted: Thu Jul 05, 2012 7:50 pm |
seems weird to me but anyway cheers
got_bar_work
 Posted: Fri Jul 06, 2012 9:23 am |
The front is a 2.1 ratio as the spring is only halway along the arm If u lift it 15mm The wheel moves down 30
BRAD
 Posted: Fri Jul 06, 2012 6:55 pm |
ohhhh so that makes sence so thats what shandy ment by putting 60mm at front it'll be 120mm cheers got_bar_work
iceland
Joined: Mon Mar 14, 2011 11:59 pm Posts: 34 Location: iceland
 Posted: Thu Nov 01, 2012 10:40 am |
these are 38" tires and yeas it is in iceland
got_bar_work
 Posted: Thu Nov 01, 2012 11:46 am |
Has the rear doors been cut into Any chance of some closeups of the rear guards
DarkHorse
 Posted: Thu Nov 01, 2012 3:47 pm |
I want to know where the flares are from...
