It is currently Fri Nov 06, 2026 9:00 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
Post Posted: Sat Aug 25, 2012 6:47 pm
may be massivly overfueling then!!
Post Posted: Sun Aug 26, 2012 1:53 pm
Well my issue was fuel pressure. Reg doesn't open till about 250kpa I was only getting 40 fixed the pump and fired straight up. I thought I had heaps of pressure because when I took the feed line off it was under pressure
Vehicle: SJ51T
Post Posted: Sun Aug 26, 2012 2:40 pm
How did you get the pump to push more fuel through?
Post Posted: Sun Aug 26, 2012 6:13 pm
Well I had a faulty pump, new out of the box. It couldn't hold pressure I just took it back got a new one, Now works fine
Vehicle: SJ51T
Post Posted: Sun Aug 26, 2012 7:05 pm
Ah OK. I'm wondering if mine might be faulty. I forgot to mention that if I leave the motor for a while it takes agers to start like the pump has to prime the line everytime.
Post Posted: Sun Aug 26, 2012 7:42 pm
Well I had a pressure guage on my line and the return line off I could start the pumps watch the guage go up with nothing out the return then once it pressurized (quickly) fuel would pump out of the return line.
When I saw your post for the first time I couldn't believe that u wrote what you did, I was literally going to write the same thing so I would definitely look at the pump I would bet my left nutt that will be your problem
Post Posted: Sun Aug 26, 2012 11:49 pm
priming should take 1-3 seconds.
pull the plugs out and see what color they are.
Vehicle: SJ51T
Post Posted: Mon Aug 27, 2012 7:37 am
the pump primes for the required amount of time. Its the fact that I have to turn it over for way to long before it starts.
Plugs are black.
Post Posted: Mon Aug 27, 2012 9:09 am
running rich!! fpr is fucked mate!
surprised its not blowing clouds of black smoke!
Post Posted: Mon Aug 27, 2012 12:56 pm
Lol reheheheally?? Deffo points to it! What did you expect when the OP said he wasn't getting any fuel from the return right at the first post?.....
Post Posted: Mon Aug 27, 2012 1:03 pm
i was thinking along this line however its good to rule everything out as you can!
you guessed this one right tho!
Post Posted: Mon Aug 27, 2012 1:04 pm
jonno_racing wrote:
experience. these are the exact symptoms of a tps playing up... played this game more than once.
pompoms cuzz-tec the GTI guy :thefinger:
Post Posted: Mon Aug 27, 2012 1:18 pm
That process works but it usually end up time consuming and costly if you keep throwing parts at it until its solved. All I was trying to say was to OP did list an issue with the fuel and clearly that is a problem. So in logical sense wouldn't you solve this problem first before jumping to other possibilities?
Matty the regulator can seize if it was left dry for a while. Just for clarification can you post a pic of your fuel rail, inlet, reg and return? It might also run a fuel pulse accumulator on the other side of the rail to the reg which could be mistaken as being the reg.
Dan
Post Posted: Mon Aug 27, 2012 1:34 pm
not when you have spares mate. as he obviously did.
also its a whole lot harder to diagnose over the internet mate!
i have also run my gti with a fully blocked off FPR and it ran clear!! so depends on the fuel pump on that one mate!
Vehicle: SJ51T
Post Posted: Mon Aug 27, 2012 5:32 pm
Jr: I'll post a pic of it tomorrow as its not at my house. I brought a new 2nd hand fuel rail and fuel pressure reg, installed it today and I noticed that it did run a little better and I was getting more fuel coming out of the return. But its still stuttering when the throttle is pressed and its still stalling out after a short time. I've ordered a new pump Also.
Vehicle: SJ51T
Post Posted: Tue Aug 28, 2012 4:35 pm
Heres a picture of the old rail I took out.
Post Posted: Thu Aug 30, 2012 10:39 am
Cool!
So those 3 pipes on the left in order are inlet, regulator vacuum reference and return.
Vehicle: SJ51T
Post Posted: Sat Sep 01, 2012 7:53 am
OK. I think its all sorted. Looks like my original pump and the fuel reg died at the same time. With the new pump its running much better.
Thanks for everyone's input!
Post Posted: Wed Sep 05, 2012 8:49 am
Good news
Users browsing this forum: Google [Bot] and 68 guests
