It is currently Tue Oct 20, 2026 10:03 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
Vehicle: 2003 SQ625 Auto
Post Posted: Fri Mar 24, 2017 8:34 pm
30ONA wrote:
Yes. In my case it was ecu, key and the immobilizer and areal were integrated in one unit in the steering column.
I take it you sent all of your components away to be fixed ?
Where did you send it, what price was it (incl postage) ?
Post Posted: Fri Mar 24, 2017 8:45 pm
Rhinoman. But it will help him if you have a diagnosis first, a code. Mine was not primarily an ecu issue. But take my word for it VERY reasonable. I'll pm you.
Vehicle: sc100 se416 mightyboy
Post Posted: Sat Mar 25, 2017 12:17 am
jono165 wrote:
We've got GV's starting to appear in u-pull-it wreckers in Victoria now so its probably possible to find a cheap ecu. I would assume that as long the used ecu matches your engine/gearbox combo theyre probably all the same?
Has to be a 03-05 GV ECU the earlier GV ECUs are different.
Why make your Suzuki like a Vitara, Just get one.
Post Posted: Sat Mar 25, 2017 5:43 am
You can buy a phone car for under 1000 pull the bits you need, part the rest of the car and get your money back. There are two on gumtree now, autos. But I feel like yours is manual, Here is a v6 manual one.
Please view this ad:
Suzuki Grand Vitara,
http://www.gumtree.com.au/s-ad/kingaroy ... pp_android
Price: $1,000 Negotiable
Download the application from the Google Play Store.
http://goo.gl/7NzhP
Vehicle: Which one?
Post Posted: Sat Mar 25, 2017 7:09 am
Buy an entire car, get one with a steel front diff if you can, sell some parts and you will get your money back and have a free ECU and immo keypair. The front housing alone is worth a couple of hundred alone and all of the rest of the parts will add up quickly.
Post Posted: Sat Mar 25, 2017 9:33 am
Thanks for the info fellas.
I don't have any space for another not going vehicle, so will see if i can find any parts from a wrecker, if no luck I'll consider sending my parts away, or sell the good bits from my car :(
Post Posted: Sat Mar 25, 2017 3:02 pm
Got to say although I didnt have any expensive failures on my old gv. I'm so glad I don't own one anymore, as they're a bloody expensive car to run for what they are. Even worse once lifted.
Users browsing this forum: Google [Bot] and 202 guests
