It is currently Sun Oct 18, 2026 3:49 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2
Post Posted: Tue Apr 05, 2011 1:31 pm
:oops:
Alright, my searching skills are obviously not up to their usual standard tonight :lol:
thanks mate!
So from reading that thread, I can assume the new hotness in o2 sensors is the NTK one Greg mentions which supposedly plugs right in and is cheap cheap? :)
Moses' SQ625 GV Pig
Post Posted: Tue Apr 05, 2011 1:49 pm
yeah, i'm thinking it's the go... my bosch one after nearly 70,000kms is starting to throw the odd o2 error code, i was going to grab one of the NTK's.
Post Posted: Sat Oct 29, 2011 12:19 am
Stuey wrote:
For the record, mine turned out to be a faulty coil pack, not an oxygen sensor. The oxygen sensor was throwing up the code, but is was caused by an incorrect burn in one of the cylinders due to the stuffed coil pack. If you still need the codes sent through, I can..... but I'm sure Gus will sort you out.
How did you deduce that it was the coil pack not the O2 sensor?
2002 SWB GV
Lifted and Locked
Vehicle: 97 SV420/627 SWB Vitara
Post Posted: Sat Oct 29, 2011 5:04 am
It was a fair while ago but I think it was more or less a trial and error thing. The coil packs were the cheaper option so I changed these out first. Fortunately, this rectified the problem. I think the car was "missing' occasionally and hesitating under load when accelerating which lead me to believe there was a missfire in one of the cylinders ----> = coil pack.
Lifted, Locked & Loud. Expensive Little Toy...
Post Posted: Sun Oct 30, 2011 8:23 pm
steak_knife wrote:
atari`s on the money & Suzuki o2`s as you say, $$$$$$$$$$$$$$$$$$$$`s.
E10 run`s to clean & the o2 thinks its running lean, so it richens up till it pings, Then drops off to lean again, over & over again, Ecu think o2 is faulty & o2 still thinks it`s running lean.
It`s only 4 wire`s to change over & thay react quicker to (aftermarket that is)
So any suggestion what the best feul for a j20a??
Post Posted: Mon Oct 31, 2011 5:25 am
98 :helloo:
Post Posted: Tue Nov 01, 2011 12:19 am
Thanks mate
Vehicle: Jeep
Post Posted: Sun Nov 06, 2011 7:27 am
steak_knife wrote:
98 :helloo:
I wouldnt use anything less than 98 in any Zook ! :wink: :D
Vehicle: Suzuki
Post Posted: Mon Aug 26, 2013 10:25 am
Hi guys I see that you have to bridge the terminals on that plug under the bonnet but I can not seem to find that plug anywhere, I have a 2004 grand vitara v6 can anyone help me, I have found the obd2 plug under the drivers dash but that's all I can find. Thanks lars
Post Posted: Mon Aug 26, 2013 10:53 pm
should be near the RHS strut tower behind the airbox on the vertical section of the inner guard.
Vehicle: Suzuki
Post Posted: Tue Aug 27, 2013 6:33 am
That's near the airbox and ill be stuffed if I can find it
http://s154.photobucket.com/albums/s272 ... ction=view¤t=null_zpsfbe1a323.jpg&evt=user_media_share
Post Posted: Tue Aug 27, 2013 6:45 am
MacDaddy wrote:
steak_knife wrote:
98 :helloo:
MacDaddy wrote:
SierraDan wrote:
Macdaddy are you just skimming this thread?
Its a fuel. Your car will move with it in the tank.
But, its like when you have a Redbull and its really good, then next time you get a Sugarfree Redbull and its still a Redbull, but its just not quite right and.you drink half and chuck the rest.
Same thing. Its crap, deal with it.
You seem to be trying to convince yourself to use it because its now available.
NO, i am reading every reply...
I understand, and good analogy...
Nope, just want to make an " Informed " decision... and, if you read my last reply further up, i decided Not to try the E fuels, they are just to iffy, i will stick to Premium 95... :D
Vehicle: Jeep
Post Posted: Tue Aug 27, 2013 2:36 pm
Chop wrote:
MacDaddy wrote:
steak_knife wrote:
98 :helloo:
I was waiting for someone to jump on that, even though nearly 2 yrs ago, i did try 98 for a while back then... since then, i have become more informed about the fuel i use, and a big point, the cost of 98 Vs Benefits, just didnt add up, its too expensive now, so i went with the mid range option of 95... :D
Vehicle: Suzuki
Post Posted: Wed Sep 11, 2013 10:18 am
So could anyone see the plug in that photo?
Post Posted: Wed Sep 11, 2013 10:36 am
it should be right there... 8O
got any other engine bay shots?
Vehicle: Suzuki
Post Posted: Wed Sep 11, 2013 11:05 am
Can get some, is there any other location they hide them?
Post Posted: Wed Sep 11, 2013 11:30 am
try the other side.
Vehicle: SWB Sierra
Post Posted: Wed Sep 11, 2013 11:40 am
There are a couple of plugs on the firewall, right hand side of engine. Have no idea if they are the monitor coupler though.
Vehicle: Suzuki
Post Posted: Wed Sep 11, 2013 11:57 am
Yeah I have searched high and low cant seem to locate it, where do the wires feed from the ecu?
Vehicle: SWB Sierra
Post Posted: Wed Sep 11, 2013 12:52 pm
Does it definitely have one?
Post Posted: Wed Sep 11, 2013 1:11 pm
maybe they eliminated it on the later ones?
FSM shows it being near the washer bottle by the strut top, what side is the washer bottle on the GV's? i'm guessing LHS going by the lack of one in the link above. :?
Vehicle: SWB Sierra
Post Posted: Wed Sep 11, 2013 1:34 pm
Yep, washer bottle is left hand side, between the inner and outer guards.
You would think I would have noticed it while pulling the loom out of the GV, not a good start to the engine conversion.
Vehicle: Suzuki
Post Posted: Wed Sep 11, 2013 6:37 pm
http://s154.photobucket.com/albums/s272 ... ction=view¤t=null_zps25af7197.jpg&evt=user_media_share
http://s154.photobucket.com/albums/s272 ... ction=view¤t=null_zpscb1d2ae5.jpg&evt=user_media_share
http://s154.photobucket.com/albums/s272 ... ction=view¤t=null_zpsb00e4dbf.jpg&evt=user_media_share
Some more pics can't find a thing, anyone in north brisbane have a scan tool I could plug into?
Post Posted: Wed Sep 11, 2013 6:40 pm
shit hey, it's definitely not in those pics... whats in the engine bay fuse box? :?
Vehicle: Suzuki
Post Posted: Thu Sep 12, 2013 7:22 am
See the fullsize version at: http://s154.photobucket.com/albums/s272 ... ction=view¤t=null_zps8d6263ca.jpg&evt=user_media_share
That's the fuse box
It must have one thats the sticker that says how to set timing to bridge the connector
http://s154.photobucket.com/albums/s272 ... ction=view¤t=null_zps9eebc37b.jpg&evt=user_media_share
Vehicle: Suzuki
Post Posted: Fri Sep 13, 2013 6:42 am
Talked to an auto elec, his system said it should be in the spot near the airbox (if fitted) maybe mine doesn't have one, is there any way to short the obd 2 plug to get the codes or will I just have to buy a scan tool.
Users browsing this forum: Google [Bot] and 167 guests
