It is currently Thu Oct 22, 2026 12:00 pm
Post new topic Reply to topic  [ 95 posts ]  Go to page Previous  1, 2, 3, 4  Next
Post Posted: Fri Oct 30, 2009 11:08 pm
Jimny = Unity Bearing = not adjustable
I drove every day on a bearing that was loose for 9 months (cant rush perfection) I doubt another weekend will matter much :)
Easy way to check where the wobble is, if it goes away with somebody holding the brake down its the wheel bearing, if its still there its something else, likely the kingpin bearings
Post Posted: Fri Oct 30, 2009 11:19 pm
Cheers Scrawn, I have a feeling the bearing will still be OK... fingers crossed. It's not making any noise but I guess I won't know until I have a look.
Post Posted: Sat Oct 31, 2009 12:24 pm
Thanks Royce. I had another look this morning. I jacked up the RHS front so I could jiggle the wheel properly and while I was underneath (I'd been relying on someone else looking while I jiggled... Haha that sounds funny)
Anyway I'm pretty sure that the King Pins are the culprit, prob the bearings, and could do with new knuckle pivot scraper thingys while I'm at it. The movement/looseness is all at the knuckle.
Post Posted: Sat Oct 31, 2009 12:27 pm
the seals should be dont pretty often, 5000km in 'severe' conditions.
the culprit is obviously your wheels, you should really swap with me to fix it :)
Post Posted: Sat Oct 31, 2009 12:32 pm
LOL a lot
I guess I'm bad. I've never done the seals but they've only done 140,000km.
Do you reckon the King Pins will be OK? I was thinking I'll grab some King Pin bearings and scraper seals today and chuck them in.
Post Posted: Sat Oct 31, 2009 12:34 pm
LOL a lot
There aren't any actual king pins in your setup, that term is used pretty loosely :lol: Once you've replaced the bearings it should all be ok.
Post Posted: Sat Oct 31, 2009 12:36 pm
It's the term from the manual
Post Posted: Sat Oct 31, 2009 12:51 pm
I always thought the pins were the kingpins and the bearings the kingpin bearings, just a different layout to trucks and old Holdens
Make sure you are able to set the preload how the book says to do it, its pretty critical and the difference between getting another 140k out of them and fixing them up in 6 months
Post Posted: Sat Oct 31, 2009 12:57 pm
Not saying you're wrong, just in my mind they are swivel bearings. This is what I think of when I hear the term king pin
Post Posted: Sat Oct 31, 2009 1:03 pm
Can't find anything about preload just Torque specs for the Kingpin bolts.
Also for the spindle bearings they mention lithium grease. Does this also apply for KP bearings? Or just a quality bearing grease will suffice?
Post Posted: Sat Oct 31, 2009 1:08 pm
I'm just going by what this EBAY PDF manual says. How about the thingys that hold the hub to the axle tube?
:lol: :lol:
Post Posted: Sat Oct 31, 2009 1:13 pm
I use a Moly (black) grease for the cv's and 'king pin' bearings and an Extreme Pressure (red) grease for the wheel bearings. Bolts are just done up tight but when you remove the king pins you'll see shims under them, make sure they go back in the same way.
Post Posted: Sat Oct 31, 2009 1:19 pm
Cheers. There's also a KP bearing outer race. Do you guys usually replace this at the same time or are they quite re-usable?
Also trying to source the bearings this morning. Am waiting for MOTOSPECS to open/answer. Any other ideas? SS at Lawnton don't open Sat.
Post Posted: Sat Oct 31, 2009 1:20 pm
Replace them, they only take a few minutes to knock out and in.
Post Posted: Sat Oct 31, 2009 1:22 pm
Motorspecs may not be open today, they're pretty casual down there. If all else fails try Ripco, check price though.
Post Posted: Sat Oct 31, 2009 1:24 pm
They don't have them :(
Post Posted: Sat Oct 31, 2009 1:25 pm
Going to assume jimny is the same as sierra, you put the swivel bearings in and do it all up without the scraper seals fitted and remove the steering arm and hook a spring scale in there (like they use to weight fish) and pull on it slowly and note what 'weight' it reads when it starts to move the hub, there is a set range it has to be in, to make it move at a higher weight you remove shims, at a lower weight you add
then you pull it all apart again and grease it up and assemble with the seals and stuff, bit of work but you dont have to worry about it again afer that
Post Posted: Sat Oct 31, 2009 1:38 pm
Spring scale attached between the steering arm ... and chassis?
Just read it again... between steering arm and my hand... LOL
Post Posted: Sat Oct 31, 2009 1:40 pm
no you pull on it
Just edited my previous reply
Post Posted: Sat Oct 31, 2009 1:52 pm
Oh well, looking like I'm not going to be able to get the parts today but I've got some great instructions here, thanks guys.
Hopefully I won't be doing too much damage in the meantime, will just have to take it easy although it is better at higher speed... centrifuge I guess.
I might get a full hub seal and bearing kit through the week and do the whole lot. Am I able to get spindle bearing out without hydraulic press, I'm thinking a large socket and rubber mallet ???
Post Posted: Sat Oct 31, 2009 2:01 pm
Is this a reasonable price??
He's located in Banyo
http://cgi.ebay.com.au/Swivel-Hub-Kit-S ... 318wt_1167
Post Posted: Sat Oct 31, 2009 2:05 pm
$170 seems a bit exxy to me although the wiper seals are genuine. Be careful you don't bugger the spindle like Rusho has done
Post Posted: Sat Oct 31, 2009 2:11 pm
Japanese bearings sound like a good thing too. What did Rusho do to his spindle?
Post Posted: Sat Oct 31, 2009 2:15 pm
Loose wheel bearing ground away the spindle, now there is too much tolerance and the bearing doesn't sit tight on it. He's replacing it with a Vit one.
Post Posted: Sat Oct 31, 2009 2:20 pm
Not that I would know but I'm pretty sure the wheel bearing is fine. Definitely getting the movement at the KPs. Hopefully I don't do similar to the KP.
Post Posted: Sat Oct 31, 2009 2:31 pm
I thought my KP were gone also, after I finished rebuilding them, Steknig came over to have a looky for me, and found what scrawny mentioned. I have some vit hubs now, just need to get the bearings. Does anyone know what year the vits had cone shaped bearings? I got a set of coily/vit/jimny bearings off weaves. There not going to be much help now. Ayone wanna buy a brand new set off me??
Post Posted: Sat Oct 31, 2009 2:46 pm
Yeah they suit my Jim I'd be interested. I take it they are unused and unfitted. How much are you after? I'm a little poor ATM.
Post Posted: Sat Oct 31, 2009 3:07 pm
I would say earlier model ones did. Any bearing shop will be able to tell you
Users browsing this forum: Google [Bot] and 198 guests
