It is currently Mon Nov 09, 2026 2:20 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2
Post Posted: Thu Dec 24, 2009 1:00 am
No. :roll:
I once thought I was a tree! :P
Post Posted: Thu Dec 24, 2009 1:04 am
steknig wrote:
No. :roll:
8O what sort of tree :? :P
Post Posted: Thu Dec 24, 2009 1:10 am
steknig wrote:
No. :roll:
lol sorry im not a hippie :P dont make love to trees!!
i cant see how that could be any fun just imagine the splinters.... 8O
Post Posted: Thu Dec 24, 2009 1:53 am
I heard megan fox used to be a man??? you might be onto something
Post Posted: Thu Dec 24, 2009 4:07 am
What dont tell me that shes hot :D
Post Posted: Wed Mar 24, 2010 11:13 pm
hey everyone,
i got a few more questions.
i hit a pretty big bump on a trip at xmas time and since then the jimny has been pulling to the left. i went to get the wheel alignment done and they said it was the camber on the front right tyre that is causing it to pull.
its at -1.5 degrees. i then spoke to some suspension people and they said something must be bent and you cant adjust the camber on a jimny. he said they wont be able to tell whats bent and will have to replace everything in the front right side.
that sounds bloody expensive.
is there a way for me to find out what part is bent so i can narrow down what needs to be replaced. i have had a good look under there but cant see anything outa the ordinary.
also i am going to order my lift kit at the start of next week.
i have been getting quotes for TD, OME and 1 dobinsons. all 40mm lifts.
which one do you think would be the best??
Post Posted: Thu Mar 25, 2010 1:16 am
I've got the OME kit installed in my 2008 Jimny a couple of days before Xmas and it's been fine.
The ride felt a little wobbly after getting it done but after a while you get used to it.
Post Posted: Wed Jun 02, 2010 5:22 am
I want to do a number of things to the jimny, so i thought i would ask you guys how easy these things are, if there are any tips or things to watch out for and if i need any special tools.
things to do:
change engine belts (they're cracked)
change oils: xfer case, diffs, transmission.
radiator flush, new coolant
change the clutch
change brake pads
thats all i can think of for now,
i am not very mechanically minded so do you guys reckon i should just get a mechanic to do it for me.
any help appreciated. cheers in advance
Post Posted: Thu Jun 03, 2010 7:03 am
everything exepct the clutch isnt very hard. if your keen to have a go get yourself a workshop manual and have ago. just make sure u got enuf tools to do the job. you dont need anything special just a few spanners and sockets ect.
only thing to rember with your drivline oils is to take the filler plug out BEFORE the drain plug, casue if u drain the oil and cant get the filler open well ur up shit creek.
get the manual and see how you go, i wouldnt do the clutch they are a pain if you dont know what your doing.
Post Posted: Thu Jun 03, 2010 12:23 pm
just did the clutch on my jimny. it was a real pain!
the middle cross-member gets in the way allot and getting the gear box in and out is really hard. if you do it yourself i would suggest just sliding the gear box forward and changing the clutch with the gap.
i really wish i never took the gear box out. many harsh words were said trying to get the gear box back in.
i have a ome lift kit and i'm really happy with it. i thought it wobbled less with the ome kit. (my shocks may have been stuffed)
Post Posted: Tue Dec 27, 2011 12:41 am
Hi I have a 2001 zuki with a G16A motor fitted i have just purchased this car and it is surgeing all the time replaced coils and leads plugs and got the local zuki to put it on diagnostic but no faults shoed up. Can someone please give me some idea's thanks.
Vehicle: Sj70 tintop
Post Posted: Tue Dec 27, 2011 1:21 am
^^ wtf?
it has a 1.6 carby engine in it?
you sure?
Sj70 tintop
Vehicle: Jimny!
Post Posted: Tue Dec 27, 2011 10:16 pm
Dude, you might have more luck if you don't post it in a thread from over 2 years ago, go to the "suzuki talk" forum and click "new topic" start your own topic about it with a heading related to your problem.
Users browsing this forum: No registered users and 84 guests
