| Author |
Message |
Fatzook
Joined: Sat Oct 27, 2007 11:30 pm Posts: 14977 Location: The Hills
 Posted: Sat Apr 30, 2011 12:57 pm |
dave91 wrote: what about on a coily?
A coily is a sierra. Sierras are easy to fit with 31's. Gearing is easy too. Just fit a leafy case with gears. Its not alot of work at all.
_________________ 2013 GV 1998 SV420 ute
dave91
Joined: Sun Mar 27, 2011 11:37 pm Posts: 411 Location: Brisbane
 Posted: Sat Apr 30, 2011 1:00 pm |
ok so for what i want i think a coily is the go (I'm not gay btw) just because it sounds easier to get everything for.. right?
_________________ Every problem can be solved with a Ratchet.
Fatzook
 Posted: Sat Apr 30, 2011 1:01 pm |
Given that the jimny is newer, you will get more bang for your buck with a coily.
mondo
Joined: Wed Dec 29, 2010 10:18 pm Posts: 481 Location: Jimboomba
 Posted: Sat Apr 30, 2011 1:43 pm |
i'd much prefer my coily over a jimny anyday. coily with a g16b, blow away any twin cam jimny. and if you find yourself outdriven by a coily with all your extra upgrades, who's gay then!!!!
303zuke
Vehicle: LJ50V, SJ70
 Posted: Sat Apr 30, 2011 2:07 pm |
I'm not at all certain on this, but I have a strong suspicion that the Early Jimny case (Non-VVT) is the same case as used in the SJ80. Both have the same ratios and basic arrangement. I don't have any parts lists or technical info on the Jimny, but why would Suzuki create an entirely unique transfer case for one model run that lasted a year or two?
Does anybody have a Coily and Jimny tranfer cases they can compare?
If they are the same, then the APIO and Trail Jimny gearsets will also fit the Coily. This doesn't make them any cheaper than fitting a gear driven case from a leafy, but it's an option.
atari4x4
 Posted: Sat Apr 30, 2011 2:22 pm |
i've got NFI of the workings on a coily or jimny
MacDaddy
Joined: Thu Mar 26, 2009 10:30 pm Posts: 10453 Location: Perth, Australia
Vehicle: Jeep
 Posted: Sat Apr 30, 2011 4:02 pm |
Fatzook wrote: MacBear wrote: dave91 wrote: The only difference between vz and vy is the front lights and speedo! Haha. so a jimny is the better option? Is a 97 a coily? And what is a castor kit? Personally, i would take the 97 coily over the coily Jimny any day !  Personally I'd buy a 97 vitara over both of these heaps of shit.
If it was a choice between a 97 Coily, a Jimny, and a 97 Vitara, i would also take a 97 Vitara !
dave91
 Posted: Sat Apr 30, 2011 9:36 pm |
How hard is it to put a leafy transfer case into a coily? does it just swap straight in?
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5946 Location: Northcliffe, W.A.
 Posted: Sat Apr 30, 2011 10:48 pm |
mr_ron wrote: monkey wrote: Get a jimny if you want bolt on mods...or get a coily if you don't want bolt on mods apart from TSOR front bar  Or get a Vitara if your still in the closet or ultimately get a Leaf sprung Sierra if you want an awesome 4x4 with unlimited potential and options
or, get an LJ if you've got real balls
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Sat Apr 30, 2011 11:00 pm |
dave91 wrote: How hard is it to put a leafy transfer case into a coily? does it just swap straight in?
You will need the Leafy case, mounts and jack shaft. Then it is a bolt in job
Fatzook
 Posted: Sun May 01, 2011 1:32 am |
Rusho wrote: dave91 wrote: How hard is it to put a leafy transfer case into a coily? does it just swap straight in? You will need the Leafy case, mounts and jack shaft. Then it is a bolt in job
Agreed.
I would not discount buying a coily due to lack of gearing options, when it is so easy to swap in a leafy transfercase. Its just not a good enough reason to buy a Jimny IMO
Benz
Joined: Mon Oct 27, 2008 10:30 pm Posts: 1006 Location: Cervantes WA
 Posted: Sun May 01, 2011 2:33 am |
303zuke wrote: atari4x4 wrote: Rusho wrote: atari4x4 wrote: + there is so much more aftermarket support for the Jimny's. Like what?? pretty sure there are few different options for bar work? air lockers, lift kits like the Off Road Armory kit, upgraded CV's, transfer gears from APIO & the other mob that i can't remember their name + basic spring lifts from the regular brands like OME, TD etc all off the shelf. can you even get gears for a coily case? : how long was the build run on the SJ80? I'm not at all certain on this, but I have a strong suspicion that the Early Jimny case (Non-VVT) is the same case as used in the SJ80. Both have the same ratios and basic arrangement. I don't have any parts lists or technical info on the Jimny, but why would Suzuki create an entirely unique transfer case for one model run that lasted a year or two? Does anybody have a Coily and Jimny tranfer cases they can compare? If they are the same, then the APIO and Trail Jimny gearsets will also fit the Coily. This doesn't make them any cheaper than fitting a gear driven case from a leafy, but it's an option.
apio gears cost heaps....
leafy transfer swap would be cheaper (at least better value) and give you more options when it comes to bigger rubber as apio gears only change low range.
Rusho
 Posted: Sun May 01, 2011 2:40 am |
Benz2369 wrote: apio gears cost heaps....
Kinda what I was getting at...sure coily's have their weak points, but if you are willing enough to persevere with things they are easy enough to mod
303zuke
 Posted: Sun May 01, 2011 3:53 am |
[quote="] This doesn't make them any cheaper than fitting a gear driven case from a leafy, but it's an option.[/quote]
Kinda what I was getting at, too!
