It is currently Sun Oct 25, 2026 1:20 am
Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3
Post Posted: Tue Dec 08, 2009 3:29 pm
TASSIETOYUKI wrote:
zookernator wrote:
TASSIETOYUKI wrote:
zookernator wrote:
uh huh.. i see. Unfortunatly an engineer wont look at this vehicle :oops:
Fixed for ya :wink:
oh now thats harsh!! :cry:
Its all in good fun buddy :wink:
But i have a blue plate and you dont, na na :P
Gunna "try" and get round today or tommorow :roll:
maybe tonight would be best?
get around where? To my place?? :lol: hehe, tonight is a good night, be able to give me a hand lifting the cab off.. anytime around 430/5 ish.. i'll supply the beers ;) hehehehe
Post Posted: Tue Dec 08, 2009 4:35 pm
will do my best (looks like no lunch for me today :roll: )
Post Posted: Fri Dec 18, 2009 10:49 pm
i found a holden jackaroo parked next to my zook this afternoon and measured the lower arms, they are 870 - 875mm. 170mm bigger then anything else 8O
i did not get to have a look at the upper arms
Post Posted: Sat Dec 19, 2009 2:44 pm
8O woah.. their long!! Good work on the find!!
Post Posted: Sat Dec 19, 2009 3:44 pm
As i have said before im not a link king or have ever done any link's myself, But i would advise you just buying thick wall tube or RHS (if your into booty fab) then making your own control arms.
And I would advise the complete opposite!
Telling people to make their own arms is a terrible idea. Most people won't have the knowledge and know-how to manufacture their own trailing arms. Don't get me wrong, I'm all for people 'having a go', but things like trailing arms and panhards should be left to the joes of the world, or other suitably qualified persons.
My advise... If you cannot find an OEM trailing arm that's suits your needs, either make a compromise and use shorter arms along with their inherent floors, or get some professionally made.
JMO
Pete
sorry i missed this thread for ages.
yes your spot on there, joe would be able to make his own because he can weld and fab like the best. But i was thinking along the lines of fabbing it all up then taking it to a fab shop and getting them to finish off the welds. This will cost alot less then buying already made arms, and if it's not seeing the road as a DD then it needs no inspection. im not saying that it's a dodgy build or truck just saying it has to bow to a different set of standards. With weld testing im fairly sure that an xray and looking up the strengths of the steel in use would be suffice?
also i work in a fab shop so i forget and take for granted that i have access to all the tools, know how and more qualified welders you could poke a stick at.
IMHO
josh
Post Posted: Mon Dec 28, 2009 2:36 am
Question time... I'm not far from getting the brackets welded for the control arm bushes... but im not sure if i should make the brackets so they are a tight/snug fit with each side of the bush.. or if i should leave 2mm for eg for extra play, so when the bushes are working to their max, they wont crash on themselves and bugga up? Im guessing they should be kept nice and snug, cause if you allow movement there is the oppurtinity for them to become slogged out... but thought i best double check with everyone elses opinions!
Post Posted: Mon Dec 28, 2009 5:40 am
What are the arms off? Use the specs of the brackets used on the donor vehicle. Different bushes are designed to work with different tollerances.
JMO
Pete
Post Posted: Mon Dec 28, 2009 2:04 pm
JMO
Pete
off a GQ.. already doubled check with a GQ, and they dont leave any room.. so thats what i'll also do.. thanks for the reply :)
Users browsing this forum: Google [Bot] and 264 guests
