It is currently Sat Oct 24, 2026 4:22 pm
Post Posted: Wed Feb 24, 2010 8:39 pm
I am in the process of rebuilding my 1.3l G13A engine and I am at the stage of replacing the clutch plate and pressure plate. Is there any way of doing this without the need for the alignment tool (illustrated in the manual). I understand I have to keep the clutch plate aligned as I do up the bolts on the pressure plate ??????
Post Posted: Wed Feb 24, 2010 8:50 pm
just go by eye and feel if your confident.
If not get a broomstick and wrap it in tape til its a good fit.
I never used an alignment tool to do mine.
Vehicle: jimny
Post Posted: Wed Feb 24, 2010 8:56 pm
i have used a socket extension and done it by eye, never missed yet
Post Posted: Wed Feb 24, 2010 9:23 pm
i normally pull motor and box out as one and do the rear main and g/box seal while im at it. Only cause its a pain to do if you dont have a hoist or someone to help.
Post Posted: Wed Feb 24, 2010 9:54 pm
Thanks guys will try those ideas tonight
Post Posted: Wed Feb 24, 2010 9:59 pm
I did mine by myself by eye, only took me two attempts to get it to line up
Sam
92 WT, 31" buckshots, half RUF and 6.5:1.. Low and
Post Posted: Thu Feb 25, 2010 3:31 pm
Tried the long socket idea, worked fine, thanks Eldo. She started first time after bottom end rebuild aswell, when I finally connected all leads to the ignition coil correctly, lol :) Just needs a bit of fine tuning now. Did notice the Thrust/release bearing is still noisy even with new one installed???
Users browsing this forum: No registered users and 152 guests
