It is currently Sun Oct 25, 2026 9:24 am
Post Posted: Thu Mar 25, 2010 1:18 am
hey all,
so i have to pull out my front right suspension (its a coil over strut setup with 2in lift from standard) and i want to know if i will need a spring compressor to get it out.
any help would be cool.
Cheers,
Murph.
Post Posted: Thu Mar 25, 2010 1:23 am
It would help a lot if you do. It can be done without but it is a very dodgy exercise
Post Posted: Thu Mar 25, 2010 1:42 am
i got a set if u want to buy them lol but i didnt need them when i put my 40mm suspension lift in... just jack it right up and oh get a set of rachet spanners would make the job heaps faster for undoing the top of the struts.... well when u jack it right up there is no load on the spring so you dont have to worry about there being load on it... soo good luck
Vehicle: Serria
Post Posted: Thu Mar 25, 2010 11:02 am
nar you dont need nothing jack the car up un bolt strut at top of tower then at diff and it will fall out. no special tools needed
Sj80 cab on sj70 chassis 5inch lift 1.6 turbo inte
Post Posted: Thu Mar 25, 2010 5:56 pm
you wont need spring compressors to get the spring out.
put the car on chassis stands and have a jack under the diff, when you undo the nuts and bolts for the strut tower, you can lower the jack under the diff and the strut will come out.
Users browsing this forum: No registered users and 172 guests
