It is currently Sun Oct 25, 2026 2:07 am
Post Posted: Mon Apr 05, 2010 2:58 pm
hey fellas just after some info want to look at puting some lower ratios in my difs and wondering wat i can do i have nt diff centers in mine
so wat should i have my eye out for
cheers luke
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Mon Apr 05, 2010 3:04 pm
So you currently have 3.9's?
Post Posted: Mon Apr 05, 2010 3:05 pm
umm yer i think that would be correct
-indebt 4x4 club-
Post Posted: Mon Apr 05, 2010 3:27 pm
Vitara fronts, 5.12
Post Posted: Mon Apr 05, 2010 3:30 pm
Various Vitaras will give shorter gearing...
4.6:1
4.8:1
5.12:1
Much easier to fit transfer gears before you start messing with diff ratios though.
Post Posted: Mon Apr 05, 2010 3:43 pm
ok cheers jas
-indebt 4x4 club-
Post Posted: Mon Apr 05, 2010 4:06 pm
Just a quick dumb question, do diff gears do anything to correct speedo error due to bigger tyres or do they simply make it worse still.
Made in JP. Built in WA.
Post Posted: Mon Apr 05, 2010 4:09 pm
Diff gears can correct a speedo... IF.... you pick the right ratio.
diff gears do alot of other good things, but if you have a standard t case with 33's and fit 5.1 diffs your speedo will be well inside the 10% ADR compliance rule.
Post Posted: Mon Apr 05, 2010 4:15 pm
I have no idea of what ratio I have in my suziblu, no idea of speed i was doing with the 31" tyres I put on her, So I checked with a GPS, I cannot tell the diff tween the speedo reading and the GPS, if there is a discrepancy, its that I may be a k over speed at 80k
No tacko so no idea of revs.
Post Posted: Mon Apr 05, 2010 6:31 pm
X90 has 4.3:1 ratio 5M
Steve W
Post Posted: Tue Apr 06, 2010 10:59 am
X-90 auto and imort SWB vit has 4.6:1.
This will allow you to run 32's, and 1 litre transfer with near stock speedo readings.
Pete
Users browsing this forum: Google [Bot] and 105 guests
