It is currently Sun Oct 25, 2026 5:25 am
Post Posted: Wed Apr 07, 2010 1:55 am
Has anyone come across the problem that after doing a 2" body lift on a 92 leafy SWB that when driving along in second gear it pops out. I have tried making the gear leaver boot retaining bracket smaller and even removing the boot completely but it still comes out under acceleration. Hope someone has some ideas. The gearbox has just had a complete rebuild so possibly something is not working properly.
Thanks
Post Posted: Wed Apr 07, 2010 1:58 am
u might need to cut a small amount out of ur tunnel to allow it to get 2nd gear properly i think this happends to most body lifts on sierras
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Wed Apr 07, 2010 2:02 am
Would this only help if the gear leaver was hitting the side of the tunnel becasue it goes into second and doesn't hit it at all??
Post Posted: Wed Apr 07, 2010 2:07 am
It might be the gearbox moving with the torque of the engine if you know what I mean. Might be enough to pop it out of 2nd. Do a bit more trimming :wink:
Vehicle: jimny
Post Posted: Wed Apr 07, 2010 2:31 am
check your gearbox mounts
Vehicle: lj81 stockman
Post Posted: Wed Apr 07, 2010 2:39 am
check it goes in low 4 to mine dident i had to cut some floor out
the wobble rocks
Post Posted: Wed Apr 07, 2010 3:18 am
i used an oxy torch and bent my levers ;) problem solved hahahaha
Vehicle: Sierra Utey!
Post Posted: Wed Apr 07, 2010 3:58 am
I cut and extended my levers as well as cut a bit of the floor out - although this is in my NT 1L, with 1.3L running gear - tunnel is different.
My ute..
Post Posted: Wed Apr 07, 2010 4:00 am
but still better safe then sorry
-indebt 4x4 club-
Post Posted: Wed Apr 07, 2010 12:38 pm
reason this happens is cause the rubber boot pulls you out of 2nd gear. loosen the boot, put it in 2nd and stretch the boot downward, then tighten back up. If this fails you can either keep your hand on the shifter or lengthen the section of shifter that comes out of the gearbox before the first bend, 1" should do it
Users browsing this forum: No registered users and 174 guests
