It is currently Sun Oct 25, 2026 4:18 am
Vehicle: 1987 sierra tray back buggy
Post Posted: Sun Apr 11, 2010 7:41 pm
like it says above i want to cut a hole in the firwall and run the water from the engine to the radiator inlet and then prolly from the radiator outlet to the engine inlet through the cabin of a sierra ute.
reason for this is i have a 2000 model baleno motor and the water outlet on the motor with the thermostat and temp sensor comes out of the back of the motor anr wont fit unless i cut a hole in the firewall.
also was thinking of putting a big radiator on the tray to get it up and out of the mud and shit.
so what does you all think? is there anything i have missed that may make this dangerous? i was thinking of putting a shroud over the pipes to protect against hot water pissing all over ocupants in the event of a rupture.
what sort of temp increase in the cabin would i expect from the heat transfered from the pipes to atmosphere?
cheers fellas sorry if its in the wronge catergory.
Post Posted: Sun Apr 11, 2010 7:58 pm
there is ways you can modify the housing tofit not sure if its the same as a gti motor but they can run a sigma thermostat housing or cut and weld the one u got ... but i wouldnt want to run em thru the cabin even if u do put shrouds over em if they rupture there is still gunna be hot coolant all over the place if it were my car i would run rm under they car get an exhaust shop to bend up some pipes to go front the rad to the engine and just have a frexie hose at each end .. but thats just my 2 cents ...
Post Posted: Sun Apr 11, 2010 8:19 pm
cutting the firewall at all makes your car illegal. Personally i think its a drastic solution for a simple problem.
Vehicle: MY2019 Jimny
Post Posted: Sun Apr 11, 2010 8:36 pm
Talk to Bluesuzy, he has the answers...
Post Posted: Sun Apr 11, 2010 8:45 pm
Mine is fully custom...
Post Posted: Sun Apr 11, 2010 8:59 pm
I spent some time in a patrol yesterday that had the cold lines (so only from the radiator back to the engine) for the radiator and intercooler in the cab and even idling and cold it was damn hot inside
Post Posted: Sun Apr 11, 2010 9:00 pm
It can be done without cutting the fire wall.
Vehicle: Suzuki
Post Posted: Sun Apr 11, 2010 9:22 pm
Ouch...I can imagine the scolding occupants :|
Post Posted: Sun Apr 11, 2010 9:34 pm
go to supercheap and buy a torana thermostat housing
Post Posted: Sun Apr 11, 2010 10:10 pm
x2 thats how the buggy guys do it.
And ninjadaniel I dont think legalities are an issue :wink:
Post Posted: Sun Apr 11, 2010 11:26 pm
If that is the case and a torana one will fit you should be able to use any 6 cyl holden housing from 1964 to 1985, red, blue or black holden six are all basicly the same.
Post Posted: Mon Apr 12, 2010 12:20 am
Post Posted: Mon Apr 12, 2010 1:26 am
Joe, pics of that yellow thing, STAT!
Post Posted: Mon Apr 12, 2010 3:16 am
http://www.auszookers.com/index.php?nam ... llow+thing
Post Posted: Mon Apr 12, 2010 10:07 am
Oh that one, yeah I have seen it, thought it was a new monster...
Post Posted: Tue Apr 13, 2010 5:56 am
yeah because everyones radiator hoses burst all the time :roll:
even more so when the hoses are contained within a steel shell running through the cab, do it matt, id give u a hand but im still dicking around with my axle, waiting for per to answer his phone to give me a hand with the bloody bearings
Vehicle: LJ20 LJ50
Post Posted: Wed Apr 14, 2010 1:47 am
Water boils at 100 degrees so when you OVER heat an engine the water becomes SUPER hot and this may cause them to fail. I seen a water hose fail in a car with a rear mounted radiator. It was two pipes through the passenger floor encased in another pipe which had been cut done the side to allow it to slip over the two pipes. This was the nmounted with the slot down hard up against the tunnel.
The hoses blew right next to the passenger fleg and blew down to the floor and then being water heated to about 1oo degrees it rapidily expanded to steam completly filling the passenger foot well with steam and causing third degree burns to the passenegr leg.
Yes they used inferior pipe for the radiator pipes but it still blew right where you didn't want it too.
Your car your choice but their is room in the tunnel UNDER the car
Camels have nice toes
Post Posted: Wed Apr 14, 2010 2:06 am
even if it doesnt happen all the time im pretty sure 1 time is enough i no i wouldnt want to risk geting 3rd degree burns twice in the same car i wouldnt even wanna go near in if the hoses were all new saftey is paramount hot things stay in the engine bay and under the floor and that is all there are plent if safer ways that dont cost the earth and dont hurt people if they fail
Users browsing this forum: No registered users and 136 guests
