It is currently Sun Oct 25, 2026 6:46 am
Post Posted: Sat Apr 17, 2010 12:45 am
ok yes i searched so for any one else who is looking for info look here http://auszookers.com/index.php?name=Fo ... pic&t=5293.
but my question is that every one says move them in 40mm ok so where do you measure the 40mm from? the locating hole, the inside edge, the back side edge? if some could tell me would be amazing thanks. also do i need install extended brake lines just to fit them or will i be able to fit them and extend them later as the car is off the road still?
Post Posted: Sat Apr 17, 2010 1:16 am
You can measure it from the locating hole that will be fine, as for extended brake lines you will have to fit them when you do it as the standard ones will be too short! Robb.
Bitumen...Another waste of public funds!
Post Posted: Sat Apr 17, 2010 1:20 am
ok thanks robb that sucks was hoping to get it all done this weekend :( any one have extended brake lines for sale??
Post Posted: Sat Apr 17, 2010 2:33 am
make sure you mark/scribe a reference line alone the diff tube for the pinion angle as well to ensure you dont change that by rotating the mount
Vehicle: 89'SWBsierra&84'LWBsierra
Post Posted: Sat Apr 17, 2010 2:39 am
standard swift brake lines are longer. i have they on the front of my sierra 8)
greg
Post Posted: Sat Apr 17, 2010 3:13 am
ok cool how much longer do you know long enough to suit half ruff and wt conversion?
Post Posted: Sat Apr 17, 2010 7:46 pm
greg
wat swift they out of? i'm goin to need some soon
87' sierra with 31's
Users browsing this forum: No registered users and 137 guests
