but my question is that every one says move them in 40mm ok so where do you measure the 40mm from? the locating hole, the inside edge, the back side edge? if some could tell me would be amazing thanks. also do i need install extended brake lines just to fit them or will i be able to fit them and extend them later as the car is off the road still?
You can measure it from the locating hole that will be fine, as for extended brake lines you will have to fit them when you do it as the standard ones will be too short! Robb.
_________________ Bitumen...Another waste of public funds!
Users browsing this forum: Google [Bot] and 382 guests
