It is currently Mon Oct 26, 2026 9:25 pm
Post Posted: Sun May 02, 2010 7:17 am
Hi, after several idling issues with my sierra, ive decided to rebuild the carby. I have 2 carbies to turn into 1. Problem is, the second carby that i got the other day is slighlty different.
What is the electronic thing in the pictures. Mine had 2 wires, but the other (that i plan on using) has 1 wire. I have a 3 pin connector in the car.
I joined by wire colours and left 1 pin disconnected at engine connector and it seemed to idle (sort of) but just wanted to check.
Cheers.
Post Posted: Sun May 02, 2010 7:43 am
hay how ya going. This is an idle solenoid the one with 2 wires has a positive white and negative black. with out this your car will not idle. The one with one wire is the positive wire and earths through the body of the solenoid. hope this helps ya
Post Posted: Sun May 02, 2010 7:56 am
cheers. Once i removed this and seen the head on it, it made me think that shes stuffed. which explains why the sierra wont idle (or sometimes idles) but drives ok. I actually connected the positive (black) wire (from the 1 wire one) to the black wire in the 3 pin connector. So your saying it needs to be black to white in the connector??
Vehicle: SJ80
Post Posted: Sun May 02, 2010 11:51 am
Anti Dieseling solenoid. Needs to be powered up when the ignition is on, then off when the ignition is off.
It is an electromagnet, so will probably still work even if you wire it the wrong way round...
Users browsing this forum: Google [Bot] and 301 guests
