It is currently Sun Oct 25, 2026 7:59 pm
Post Posted: Thu May 13, 2010 9:25 am
Ok time for a noob question :roll:
I wana change the gearbox oil on my vitara this weekend but i just need to know how much oil do they take?????
and does anyone know the best oil to use for a really noisey gearbox
Cheers Joe
Post Posted: Thu May 13, 2010 9:30 am
Cheers Joe
morays at 50% :wink:
Post Posted: Thu May 13, 2010 9:42 am
vmx 80 works well pretty sure made by castrol.
you could also use an additive.
wont take much couple of litres id say.
Post Posted: Thu May 13, 2010 9:45 am
Cheers Joe
Who's that shep? I have heard of Morly's. Got a pic or a link?? :P :P
Vmx80 is a Castrol product, but most brand's will have a straight 80w, how noisy are you talking Joe???
Post Posted: Thu May 13, 2010 9:51 am
Cheers Joe
both as bad as each other :)
http://www.moreysoil.com/
Post Posted: Thu May 13, 2010 9:53 am
You mean this gear shep?
Post Posted: Thu May 13, 2010 10:08 am
3.3 litres for the gearbox + transfercase- 70w/90
3.3 litres for the front & back diffs - 80w/90
an old suzuki mechanic told me to use castrol & morey's oil stabaliser :wink:
Post Posted: Thu May 13, 2010 10:29 am
Cheers Joe
Pretty bad :( its always had a winey noise since i got but now its like a metallic howl :roll:
Cheers for all your input fellas ill try this stuff out this weekend and hopefully it turns out good
Post Posted: Thu May 13, 2010 10:34 am
what ended up happening with the gearbox out of the old vit, from memory the engine was going into a sierra?
is it still kicking around...
Post Posted: Thu May 13, 2010 10:43 am
Gearbox snapped in half 8O :P :lol:
Brodie keeped the motor and wiring then the rest went to sims metal.....
Post Posted: Thu May 13, 2010 10:47 am
may just be noisy throwout bearing? doesit go away when you depress the clutch? or possibly input shaft bearing.
Post Posted: Thu May 13, 2010 10:59 am
Nah not the throwout bearing it comes on when under load......
Did you get my pm?????
Post Posted: Thu May 13, 2010 11:13 am
that's the stuff, they have a oil stabiliser that is like syncros in a bottle. :wink: :lol:
Post Posted: Thu May 13, 2010 8:14 pm
OK i just noticed on my way to work that the noise is only really there in 1,2 and 3 :? 4 and 5 gears still have the normal gearbox whine but are fine other then that....
Any ideas what it could be??????
Post Posted: Sat May 15, 2010 5:00 am
Done a oil change with vmx80 and made no differance :evil:
Any idea where i can get ahold of that moreysoil????i had a look at supercheep and autoone but they didnt have any :roll:
Post Posted: Sat May 15, 2010 7:03 am
http://www.supercheapauto.com.au/online ... 27#details
Vehicle: LWB Sierra & XL7
Post Posted: Sat May 15, 2010 7:04 am
SCA usually stock Lucas products.. Similar stuff, different brand.
I've got a small tube of Nulon gear and diff treatment. It worked really well in my commo when I had it.
'92 Vitara & Camper trailer
Post Posted: Sat May 15, 2010 10:37 am
I had another look at supercrap and found some :roll: Ill try it out tomorrow.
I went for a bit of a drive before and now after the oil change it does seem a bit quieter so hopefully this stuff helps...........
Post Posted: Mon May 31, 2010 1:57 pm
i no this is prob a stupid question but where and how do you put the oil stabilizer in? like with engine diff gbox oils or just one?
Vitara JX 1.6, straight through 2 1/4" exhaust, 2.
Users browsing this forum: Google [Bot] and 109 guests
