It is currently Mon Oct 26, 2026 2:16 am
Vehicle: Jimny, Lifted on 30's
Post Posted: Mon May 31, 2010 5:24 am
Had my jimny for 13000 km's taken it on the beach once to fraser island and afterwards extensively cleaned it. MY brake pads have worn out so i took it in to get them replaced and ive been getting a grinding scratching noise when starting. They say that the front brake pads and rotors have been rusted through from sand build up. and going to cost 579.00 to replace. They also suspect the grinding noise whilst starting is because the starter motor is full of sand? to replace 1177.73 ?
Does the components actually rust this fast? and how does the starter motor get sand in it ? if so can you clean it somehow? :twisted: Thanks guys!
Post Posted: Mon May 31, 2010 5:39 am
new reduction starter motor to suit jimny is $190 from suzi auto services in slacks creek 3208 4510
youll find that sierra & vitara rotors will fit your Jimny and wont cost more than 120 for the pair.
Can you describe the grinding noise? perhaps take a video with your phone and youtube it?
Post Posted: Mon May 31, 2010 8:33 am
ooo ill have to get 1 of those started motors, mine is starting to go. thanks mate.
i would shop around mubby that sounds really expensive. i highly doubt the brake rotors have rusted though, they are solid steel!
Post Posted: Mon May 31, 2010 8:46 am
Wow!
Expensive stuff if you can't replace them yourself!
Suzuki seems to be ripping you a new one!
Post Posted: Mon May 31, 2010 4:20 pm
Yeah im taking it to a few mechanics to get some quotes but it sounded realy expensive. But it seemed wierd that all this stuff is going wrong and rusting in such a short time. But thanks for the opinions its good to get other peoples thoughts. Thats a big difference in starter motors, 120 buks to 1000 ha ! ill have to go check it out. Thanks! :D
Jimny, 3" Lift, 30" Treps, Gears
Post Posted: Tue Jun 01, 2010 1:39 am
http://www.youtube.com/watch?v=xi_q2Y23zM0 link to youtube video sound in engine screeching?
Post Posted: Tue Jun 01, 2010 2:16 am
My lil Suzi is a beach baby, I do wash her now and then, but as she is full of rust already, its not high on the agenda, brakes, perfect as far as i know, had her 3 years or so now, on the beach a few times a week, and starter, did replace that but it was from burnt out poles, common.
Id say someone is having a go at ya, the cost is astronomical to say the least.
Post Posted: Tue Jun 01, 2010 2:27 am
i would be looking at aftermarket disks from someone like DBA or RDA, rather than going to a general mechanic go see a brake specialist...
http://www.rdabrakes.com.au/index.php/products.html
http://www.dba.com.au/
Post Posted: Tue Jun 01, 2010 2:45 am
How mechanicall minded are you?
A starter is a few wire disconnected, and 2 bolts (on g motors anyway)
To change pads and discs, it one of the most simpler jobs. I'd be looking in the rear drums also.
Post Posted: Tue Jun 01, 2010 3:08 am
Yeah im getting the rotors and brakes fixed by another mechanic much cheaper than suzuki! Just so its still under warranty. But im going to be looking on some how to video's about pulling apart and cleaning starter motor :D so hopefully it will fix it all! Thanks alot!
Users browsing this forum: No registered users and 308 guests
