It is currently Tue Oct 27, 2026 2:34 pm
Post Posted: Tue Jun 01, 2010 1:27 pm
hey guys my spotties died on me :(
i have had them on for 18 months no problems
turned them on as i was showing the missus how far they light up turned them off and then tried to turn them on a minute later and nothing :(
i checked the fuse under the dash for the spotties and it is fine
i checked both fuses for the head lights and they are fine
i can hear a clicking noise when i flick the switch also
unsure what to check next?
any thoughts guys?
Post Posted: Tue Jun 01, 2010 1:40 pm
relay
Post Posted: Tue Jun 01, 2010 1:41 pm
Check the following:
Earth is good
Relay isn't fried
Globes aren't blown
Switch hasn't died
All wiring connections
Thats about all i can think of, your relay should always click.. So don't think that it's definantly the problem just because of it
Post Posted: Tue Jun 01, 2010 1:44 pm
all wiring is good
switch how would i check this connection appears good
earth is good
globes replaced only the other weekend on one of the lights
how do i check the relays? im not electrically minded
Post Posted: Tue Jun 01, 2010 1:46 pm
they havent been submerged in water recently ??
-indebt 4x4 club-
nav 32s n winch cust rear
Post Posted: Tue Jun 01, 2010 1:49 pm
no water
Post Posted: Tue Jun 01, 2010 1:50 pm
im thinking it may be the relays maybe
any idea how you check these
Post Posted: Tue Jun 01, 2010 2:00 pm
a multi meter should be able to give u some indacation as to if ur relay is working properly or not
-indebt 4x4 club-
Post Posted: Tue Jun 01, 2010 2:05 pm
id say relay m8 u said how to check them ..well u could disconect the relays and conect the wires togher with out the relay in the middle if that makes any sence i think the relay is a small black box that acts as a fuse ...and relay ..but u could by pass it by diconecting it ...and retaching the right wires ...sorry long time since i put the spots in my car correct me if ur wrong ... a other idea u could diconect the spots and run the wires straight to the battery c if they are working ...my best advice take to a car sparky he will prob figger it out in 2 min flat .. and only cost 50 $
Post Posted: Tue Jun 01, 2010 3:16 pm
have you checked the halogen fluid? :lol:
seriously grab a test light & check all connections, it will be something simple like a dirty earth or a dead relay. as you were saying they were working before.
Post Posted: Tue Jun 01, 2010 3:34 pm
I would drop into SuperCheap and grab a $20 MultiMetre.. And grab a new relay at the same time, cost ya $5 tops.. if it didn't need the new relay, gives you and excuse to have double spots... duh I had a spare $5 relay floating around - so I bought $800 set of lights
Post Posted: Tue Jun 01, 2010 3:35 pm
I have had relays that only work 1 way up too, swing em over on their side and they start to play up.
Post Posted: Tue Jun 01, 2010 8:56 pm
the click is probably the relay clicking
how do you have the fuse for the spotties under the dash? normally that line would run from teh battery to pin 30 or 87 on the relay
have a look at the relay and get somebody to help by flicking between high and low beam whole you hold the relay so you can confirm its clicking on and of, thats a good start, next get a test light and check you have power from teh battery at either pin 87 or 30, if you dont then track back to the battery to see whats stopping it, like another fuse.
If you do then check you have power coming on on the other of those 2 terminals when the lights would normally come on, if you dont its likely the relay, if you do next run down to your lights and see if you have power coming on there, if you dont its the wiring somehere if you do next see if you have power on the EARTH wire from your lights, if you do your earth needs fixing if you dont its time to look in the lights for blown bulbs or something
Vehicle: '94 suzuki maruti
Post Posted: Tue Jun 01, 2010 11:22 pm
that clicking is the relay, which to me suggests that its fine. doesnt mean it isnt the problem, but definitely get a multimeter. i got a crappy one for $10 from supercheap, but its helped me solve a few electrical gremlins so far. best bet is to start at the bulb, the two wires at the bulb, test them to see if theyre getting power with the switches on, then work backwards from there...
Post Posted: Wed Jun 02, 2010 6:59 am
sorry i meant the left and right head lights fuses under the dash sorry
Post Posted: Thu Jun 17, 2010 7:28 am
Mystery FIXED guys
got a call at work to say my headlights where left on wrong my head lights where not on but somehow my spotlights where ON!!!!! must have leftt he switch on
so the Mystery not working spotties NOW work however no freaking idea as to why they stopped for 3 weeks :(
each light has a seperate earth so not likely thats the problem really confused ohwell they work now WOOHOO
Vehicle: SJ80
Post Posted: Thu Jun 17, 2010 8:06 am
Cade wrote:
Mystery FIXED guys
Sounds like your car was just low on gergatrons or photons for a bit. :)
Users browsing this forum: Google [Bot] and 183 guests
